STM32L152D SD Card Problem
Question asked by CS Kim on Nov 9, 2017
Latest reply on Nov 9, 2017 by CS Kim
I'm having a problem on data logging.
I use Chan's FatFs R0.08a, SDIO 1 bit mode, DMA and ST standard library, IAR compiler.
I save 600,000 data per 200ms in SD Card using CSV format. It need about 33hours.
If I try 3 sets, 1 set is good for 600,000 data, but 1set have broken 7 data, and 1set have broken 17 data.
I tried it several times. It have Max 20 broken data. Are there anyone have similar experience?
My code brief flowchart is as below.
* every 12second for 60 data (200ms * 60 = 12sec)
1. set External 4MHz
2. f_mount(0, &fs)
3. res = f_open(&F, fileLName, FA_WRITE);
4. res = f_lseek(&F, end_no);
5.  __disable_irq();
    res = f_write(&F, wbuff, cnt, &BytesWrite);    //wbuff[] : 60 Data = about 2000 characters
    __enable_irq();
6. f_close(&F);
7. res = f_open(&F, fileLName, FA_READ);
8. res = f_lseek(&F, start_no);
9. res = f_read(&F, rSDRead, cnt, &BytesRead);
10. Verify each character
11. f_close(&F);
12. SD_PowerOFF();
13. Set Internal 4.194MHz for Battery Save
Of course I tried above flow in many many ways .
It is not easy and need long time for 1 test.
I would be so grateful if anyone could help me.
