New project Requirement using STM32f4
Question asked by Haresh Prajapati on Nov 6, 2017
Latest reply on Nov 6, 2017 by Amel N
The purpose this post is to need some suggestion. I am describing the information below.
The system will contain micro-controller, camera and SD card(SDIO Interface). For camera we have selected 5 MP DCMI Interface. We capture the picture and save this picture into SD card memory. To achieve this application we have selected STM32F407VGT6 micro-controller. So we have below queries regarding the same.
Camera description mention below
Features:
  • Onboard LDO regulators for 2.8V and 1.8V
  • Single 3.3V power input
  • 2.54mm (0.1 inch) standard pin out
  • Open source project www.ArduCAM.com supported
  • active array size: 2592 x 1944
  • power supply:
    core: 1.5VDC + 5% (internal regulator)
    analog: 2.6 ~ 3.0V
    I/O: 1.7 ~ 3.0V
  • output formats :
    (8-bit): YUV(422/420) / YCbCr422,
    RGB565/555/444, CCIR656,
    8-bit compression data,
    8/10-bit raw RGB data
  • lens size: 1/4″
  • input clock frequency: 6 ~ 27 MHz
  • shutter: rolling shutter
  • maximum image transfer rate:
    5 megapixel (2592×1944): 15 fps (and any size scaling down from 5 megapixel)
    1080p (1920×1080): 30 fps
    720p (1280×720): 60 fps
    VGA (640×480): 60 fps
    QVGA (320×240): 120 fps
  • scan mode: progressive
  • pixel size: 1.4 μm x 1.4 μm
  • image area: 3673.6 μm x 2738.4 μm
  • RAW,RGB,YUV,JPEG output support
  • External 1/4 inch high quality M12x0.5 lens
Pin Out:
Pin No.
PIN NAME
TYPE
DESCRIPTION
1
VCC
POWER
3.3v Power supply
2
GND
Ground
Power ground
3
SCL
Input
Two-Wire Serial Interface Clock
4
SDATA
Bi-directional
Two-Wire Serial Interface Data I/O
5
VSYNC
Output
Active High: Frame Valid; indicates active frame
6
HREF
Output
Active High: Line/Data Valid; indicates active pixels
7
PCLK
Output
Pixel Clock output from sensor
8
XCLK
Input
Master Clock into Sensor
9
DOUT9
Output
Pixel Data Output 9 (MSB)
10
DOUT8
Output
Pixel Data Output 8
11
DOUT7
Output
Pixel Data Output 7
12
DOUT6
Output
Pixel Data Output 6
13
DOUT5
Output
Pixel Data Output 5
14
DOUT4
Output
Pixel Data Output 4
15
DOUT3
Output
Pixel Data Output 3
16
DOUT2
Output
Pixel Data Output 2 (LSB)
17
PWDN
Input
Power down
18
RSV
NC
Reserved
19
DOUT1
Output
Pixel Data Output 1(10bit mode)
20
DOUT0
Output
Pixel Data Output 0 (10bit mode)
  • Is this micro-controller suitable for this application? If no, then please suggest us Micro-Controller.
  • Is DCMI interface good to interface with micro-controller or any suggestion regarding camera interface from your side?
  • If we will go with this approach then do we need to interface external RAM with Micro-controller? if yes then which RAM required?
Looking forward for your positive response. Kindly let us know if you need any other information.
