I2C HAL is being stuck at HAL_BUSY. Can you take a look?
Question asked by Michael Mihaylov on Nov 6, 2017
Latest reply on Nov 6, 2017 by Alan Chambers
Hey guys,
I've been playing with the STM32F411 Discovery kit and I've ran into a problem. While trying to access the MEMS sensor i've ran into a problem with the I2C communication. So basically I've gotten to diagnosing the problem to that it gets stuck at the I2C_WaitOnFlagUntilTimeout in the HAL_I2C_Master_Transmit function which returns HAL_BUSY every time. Here's my main function. I've tried the 'solutions' of other people who've had a similar problem but neither worked (Adding tickstart = HAL_GetTick();  in HAL_I2C_IsDeviceReady OR moving the __HAL_RCC_I2C1_CLK_ENABLE();).
  * File Name          : main.c
  * Description        : Main program body
  * This notice applies to any and all portions of this file
  * that are not between comment pairs USER CODE BEGIN and
  * USER CODE END. Other portions of this file, whether
  * inserted by the user or by software development tools
  * are owned by their respective copyright owners.
  * Copyright (c) 2017 STMicroelectronics International N.V.
  * All rights reserved.
  * Redistribution and use in source and binary forms, with or without
  * modification, are permitted, provided that the following conditions are met:
  * 1. Redistribution of source code must retain the above copyright notice,
  *    this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright notice,
  *    this list of conditions and the following disclaimer in the documentation
  *    and/or other materials provided with the distribution.
  * 3. Neither the name of STMicroelectronics nor the names of other
  *    contributors to this software may be used to endorse or promote products
  *    derived from this software without specific written permission.
  * 4. This software, including modifications and/or derivative works of this
  *    software, must execute solely and exclusively on microcontroller or
  *    microprocessor devices manufactured by or for STMicroelectronics.
  * 5. Redistribution and use of this software other than as permitted under
  *    this license is void and will automatically terminate your rights under
  *    this license.
  * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
  * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
  * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "main.h"
#include "stm32f4xx_hal.h"
#include "cmsis_os.h"
#include "stm32f4xx_hal_i2c.h"
/* USER CODE END Includes */
I2C_HandleTypeDef hi2c1;
TIM_HandleTypeDef htim2;
osThreadId defaultTaskHandle;
uint32_t defaultTaskBuffer[ 128 ];
osStaticThreadDef_t defaultTaskControlBlock;
osTimerId myTimer01Handle;
osStaticTimerDef_t myTimer01ControlBlock;
/* USER CODE BEGIN PV */
#define ACCEL_SLAVE_ADR_WRITE 0x32
#define ACCEL_SLAVE_ADR_READ 0x33
uint8_t LmpCnt = 0;
uint32_t microSec = 0;
/* USER CODE END PV */
static void MX_TIM2_Init(void);
static void MX_I2C1_Init(void);
void StartDefaultTask(void const * argument);
void Callback01(void const * argument);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_TIM2_Init();
  MX_I2C1_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* USER CODE BEGIN RTOS_MUTEX */
  /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
  /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* Create the timer(s) */
  /* definition and creation of myTimer01 */
  osTimerStaticDef(myTimer01, Callback01, &myTimer01ControlBlock);
  myTimer01Handle = osTimerCreate(osTimer(myTimer01), osTimerPeriodic, NULL);
  /* USER CODE BEGIN RTOS_TIMERS */
    osTimerStart(myTimer01Handle, 250);
  /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* Create the thread(s) */
  /* definition and creation of defaultTask */
  osThreadStaticDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128, defaultTaskBuffer, &defaultTaskControlBlock);
  defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
  /* USER CODE BEGIN RTOS_THREADS */
  /* add threads, ... */
  /* USER CODE END RTOS_THREADS */
  /* USER CODE BEGIN RTOS_QUEUES */
  /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
  /* Start scheduler */
  osKernelStart();
  /* We should never get here as control is now taken by the scheduler */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 100;
  RCC_OscInitStruct.PLL.PLLQ = 8;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_NVIC_SetPriority(SysTick_IRQn, 15, 0);
/* I2C1 init function */
  hi2c1.Instance = I2C1;
  hi2c1.Init.ClockSpeed = 100000;
  hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
  hi2c1.Init.OwnAddress1 = 0x43;
  hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c1.Init.OwnAddress2 = 0;
  hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c1) != HAL_OK)
/* TIM2 init function */
  TIM_ClockConfigTypeDef sClockSourceConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 100;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 999999;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
     PC3   ------> I2S2_SD
     PA4   ------> I2S3_WS
     PA5   ------> SPI1_SCK
     PA6   ------> SPI1_MISO
     PA7   ------> SPI1_MOSI
     PB10   ------> I2S2_CK
     PB12   ------> I2S2_WS
     PC7   ------> I2S3_MCK
     PA9   ------> USB_OTG_FS_VBUS
     PA10   ------> USB_OTG_FS_ID
     PA11   ------> USB_OTG_FS_DM
     PA12   ------> USB_OTG_FS_DP
     PC10   ------> I2S3_CK
     PC12   ------> I2S3_SD
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(CS_I2C_SPI_GPIO_Port, CS_I2C_SPI_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(OTG_FS_PowerSwitchOn_GPIO_Port, OTG_FS_PowerSwitchOn_Pin, GPIO_PIN_SET);
  HAL_GPIO_WritePin(GPIOD, LD4_Pin|LD3_Pin|LD5_Pin|LD6_Pin
                          |Audio_RST_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : PE2 */
  GPIO_InitStruct.Pin = GPIO_PIN_2;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pin : CS_I2C_SPI_Pin */
  GPIO_InitStruct.Pin = CS_I2C_SPI_Pin;
  HAL_GPIO_Init(CS_I2C_SPI_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PE4 PE5 MEMS_INT2_Pin */
  GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_5|MEMS_INT2_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  /*Configure GPIO pin : OTG_FS_PowerSwitchOn_Pin */
  GPIO_InitStruct.Pin = OTG_FS_PowerSwitchOn_Pin;
  HAL_GPIO_Init(OTG_FS_PowerSwitchOn_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PDM_OUT_Pin */
  GPIO_InitStruct.Pin = PDM_OUT_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
  HAL_GPIO_Init(PDM_OUT_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  /*Configure GPIO pin : I2S3_WS_Pin */
  GPIO_InitStruct.Pin = I2S3_WS_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF6_SPI3;
  HAL_GPIO_Init(I2S3_WS_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : SPI1_SCK_Pin SPI1_MISO_Pin SPI1_MOSI_Pin */
  GPIO_InitStruct.Pin = SPI1_SCK_Pin|SPI1_MISO_Pin|SPI1_MOSI_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI1;
  /*Configure GPIO pins : CLK_IN_Pin PB12 */
  GPIO_InitStruct.Pin = CLK_IN_Pin|GPIO_PIN_12;
  /*Configure GPIO pins : LD4_Pin LD3_Pin LD5_Pin LD6_Pin
                           Audio_RST_Pin */
  GPIO_InitStruct.Pin = LD4_Pin|LD3_Pin|LD5_Pin|LD6_Pin
                          |Audio_RST_Pin;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : I2S3_MCK_Pin I2S3_SCK_Pin I2S3_SD_Pin */
  GPIO_InitStruct.Pin = I2S3_MCK_Pin|I2S3_SCK_Pin|I2S3_SD_Pin;
  /*Configure GPIO pin : VBUS_FS_Pin */
  GPIO_InitStruct.Pin = VBUS_FS_Pin;
  HAL_GPIO_Init(VBUS_FS_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : OTG_FS_ID_Pin OTG_FS_DM_Pin OTG_FS_DP_Pin */
  GPIO_InitStruct.Pin = OTG_FS_ID_Pin|OTG_FS_DM_Pin|OTG_FS_DP_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF10_OTG_FS;
  /*Configure GPIO pin : OTG_FS_OverCurrent_Pin */
  GPIO_InitStruct.Pin = OTG_FS_OverCurrent_Pin;
  HAL_GPIO_Init(OTG_FS_OverCurrent_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
uint16_t Ax ;
/* USER CODE END 4 */
/* StartDefaultTask function */
  /* USER CODE BEGIN 5 */
    if (HAL_TIM_Base_Start(&htim2) != HAL_OK)
    uint8_t setupAccel[2];
    setupAccel[0] = 0x20;
    setupAccel[1] = 0x4F;
    if( HAL_I2C_Master_Transmit( &hi2c1, ACCEL_SLAVE_ADR_WRITE, setupAccel, 2, 50) == HAL_BUSY)
        HAL_GPIO_WritePin(GPIOD, LD4_Pin, 1 ); // Shows me I'm getting HAL BUSY error from the transmission
    setupAccel[0] = 0x23;
    setupAccel[1] = 0x06;
    if( HAL_I2C_Master_Transmit( &hi2c1, ACCEL_SLAVE_ADR_WRITE, setupAccel, 2, 50) != HAL_OK)
        HAL_GPIO_WritePin(GPIOD, LD3_Pin, 1 ); // Showed me something is wrong. I can't figure out debugging the board through Eclipse yet
  /* Infinite loop */
  for(;;)
  { // ACCEL_SLAVE_ADR_WRITE
      //ACCEL_SLAVE_ADR_READ
     microSec =  __HAL_TIM_GET_COUNTER(&htim2);
     uint8_t highA , lowA ,adrR;
     adrR = 0x29;
     HAL_I2C_Master_Transmit(&hi2c1, ACCEL_SLAVE_ADR_WRITE, &adrR, 1, 50);
     HAL_I2C_Master_Receive(&hi2c1, ACCEL_SLAVE_ADR_READ, &highA, 1, 50);
     adrR = 0x28;
     HAL_I2C_Master_Receive(&hi2c1, ACCEL_SLAVE_ADR_READ, &lowA, 1, 50);
     Ax = ((uint16_t)highA << 8) + (uint16_t)lowA;
     if( Ax > 0 )
          HAL_GPIO_WritePin(GPIOD, LD5_Pin, 1 );
          HAL_GPIO_WritePin(GPIOD, LD6_Pin, 1 );
     /*if( microSec < 500000 )
     else
         HAL_GPIO_WritePin(GPIOD, LD5_Pin, 0 );
         HAL_GPIO_WritePin(GPIOD, LD3_Pin, 0 );
         HAL_GPIO_WritePin(GPIOD, LD4_Pin, 0 );
         HAL_GPIO_WritePin(GPIOD, LD6_Pin, 0 );
    osDelay(1);
  /* USER CODE END 5 */
/* Callback01 function */
  /* USER CODE BEGIN Callback01 */
  /* USER CODE END Callback01 */
  * @brief  Period elapsed callback in non blocking mode
  * @note   This function is called  when TIM1 interrupt took place, inside
  * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
  * a global variable "uwTick" used as application time base.
  * @param  htim : TIM handle
  * @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
/* USER CODE BEGIN Callback 0 */
/* USER CODE END Callback 0 */
  if (htim->Instance == TIM1) {
    HAL_IncTick();
/* USER CODE BEGIN Callback 1 */
/* USER CODE END Callback 1 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
void _Error_Handler(char * file, int line)
  while(1)
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
