PWM TIM4 4KHz 50% Duty Cycle
Question asked by martin.sergio on Oct 3, 2017
Latest reply on Oct 3, 2017 by martin.sergio
   I have 2 PCB Board with a STM32F479ZGT6. I trying to generate a PWM Signal (4Khz 50% Duty Cycle) with TIM4.
   In one of them I have a 8Mhz Input Frequency and my Clock Configuration is:
static void SystemClock_Config(void)
    HAL_StatusTypeDef ret = HAL_OK;
    /* Enable Power Control clock */
    __HAL_RCC_PWR_CLK_ENABLE();
    /* The voltage scaling allows optimizing the power consumption when the device is
     clocked below the maximum system frequency, to update the voltage scaling value
     regarding system frequency refer to product datasheet.  */
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    /* Enable HSE Oscillator and activate PLL with HSE as source */
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
    RCC_OscInitStruct.PLL.PLLM = 8;
    RCC_OscInitStruct.PLL.PLLN = 360;
    RCC_OscInitStruct.PLL.PLLQ = 7;
    RCC_OscInitStruct.PLL.PLLR = 6;
    ret = HAL_RCC_OscConfig(&RCC_OscInitStruct);
    if(ret != HAL_OK)
        while(1) { ; }
    /* Activate the OverDrive to reach the 180 MHz Frequency */
    ret = HAL_PWREx_EnableOverDrive();
    if(ret != HAL_OK)
        while(1) { ; }
    /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers */
    RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
    ret = HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
    if(ret != HAL_OK)
        while(1) { ; }
   If I'm not wrong this values generate a 180MHz for the Micro and 90 MHz for the Timer Clock
   The Configuration of the TIM4 is:
    /* Timer handler declaration */
    TIM_HandleTypeDef    TimHandle;
    /* Timer Output Compare Configuration Structure declaration */
    TIM_OC_InitTypeDef sConfig;
    /* Counter Prescaler value */
    uint32_t uhPrescalerValue = 0;
    TimHandle.Instance = TIM4;
    TimHandle.Init.Prescaler         = 0;                    // --> TIM4 counter Clock at SystemCoreClock/2 = 90Mhz
    TimHandle.Init.Period            = 22500-1;              // --> 4Khz      90000000/22500 = 4000
    TimHandle.Init.ClockDivision     = 0;
    TimHandle.Init.CounterMode       = TIM_COUNTERMODE_UP;
    TimHandle.Init.RepetitionCounter = 0;
    if (HAL_TIM_PWM_Init(&TimHandle) != HAL_OK)
        /* Initialization Error */
        Error_Handler();
    /*##-2- Configure the PWM channels #########################################*/
    /* Common configuration for all channels */
    sConfig.OCMode       = TIM_OCMODE_PWM1;
    sConfig.OCPolarity   = TIM_OCPOLARITY_HIGH;
    sConfig.OCFastMode   = TIM_OCFAST_DISABLE;
    sConfig.OCNPolarity  = TIM_OCNPOLARITY_HIGH;
    sConfig.OCNIdleState = TIM_OCNIDLESTATE_RESET;
    sConfig.OCIdleState  = TIM_OCIDLESTATE_RESET;
    /* Set the pulse value for channel 1 */
    sConfig.Pulse = TimHandle.Init.Period/2;    // Duty Cycle 50%
    if (HAL_TIM_PWM_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_1) != HAL_OK)
        /* Configuration Error */
        Error_Handler();
    if (HAL_TIM_PWM_Start(&TimHandle, TIM_CHANNEL_1) != HAL_OK)
        /* PWM Generation Error */
        Error_Handler();
   With this PCB(8Mhz) and these configurations it seems that the output signal is correct
   In the other Board I change the Input Frequency to 25MHz and my Clock Configuration is:
    RCC_OscInitStruct.PLL.PLLM = 25;
    if(ret != HAL_OK)
        while(1) { ; }
    if(ret != HAL_OK)
        while(1) { ; }
    if(ret != HAL_OK)
        while(1) { ; }
If i'm not wrong this values generate a 180MHz for the Micro and 90 MHz for the Timer Clock
The Configuration of the TIM4 is the same (because the Timer Clock not change???):
        Error_Handler();
        Error_Handler();
        Error_Handler();
But the the output frequency is not 4 kHz in PD12
This is the PIN Confguration in both cases:
void HAL_TIM_PWM_MspInit(TIM_HandleTypeDef *htim)
  GPIO_InitTypeDef   GPIO_InitStruct;
  /*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* TIM4 Peripheral clock enable */
  __HAL_RCC_TIM4_CLK_ENABLE();
  /* Enable all GPIO Channels Clock requested */
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /* Configure PD.12 (TIM4_Channel1) in output, push-pull, alternate function mode  */
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Alternate = GPIO_AF2_TIM4;
  GPIO_InitStruct.Pin = GPIO_PIN_12;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
   With this PCB(25Mhz) and these configurations the output signal is not 4KHz
What am I doing wrong??
Thanks in advance
    Sergio
