sPINFamily Evaluation tool Question? & L6470 USB Driver?
Question asked by hyung_do..kim on May 14, 2013
Hi~
I'm using a development-board(EVAL6470H) with the communication board(PCC009V2).
The communication board, I recently purchased.
However, there are some problems.
1. I tested the operational state after installed the driver you provided.
  Program was sPINFamily.
However, an error occurred when I try to connect the board.
A error message window was poped up without any active connection on the board.
That phrase is as follows.
"Communication board initialization failed.
Make sure the communication board (STEVAL-PCC009V2) is
connected to the PC and board firmware has been updated to the last
version."
What is the problem?
(I tried to install it again and again, but the result was same.
 My Computer environment is Win XP.)
