VL53L0X: Verifying Changed Address
Question asked by David Yak on Sep 5, 2017
Latest reply on Oct 9, 2017 by Andrew Fletcher
I'm using one of these sensors with a nrf52 board. I'm looking for a way to check/verify if the address on one of the sensors is already set to what I want to set it to (before I try to set it, obviously). My idea was to check a register on the sensor before I try changing anything, but I've found that ST does not provide registers for this sensor so that's out of the question, and its depleted all my ideas. Anyone know how I can try this?
The reason I ask is sometimes I re-flash my code to the board without power cycling the board (therefore the sensors do not power cycle), and that causes an issue when I try to change the address of a sensor that has already had its address changed.
