STM3210B-MCKIT Hall Sensor or Encoder
Question asked by Buchholz.Alexander on Mar 12, 2013
Latest reply on Mar 14, 2013 by Buchholz.Alexander
hi,
I got the STM3210B-MCKIT and use the 3.2 FOC Lib + Workbench 2.0.
I tried to get the Encoder control to work:
- I jused the SDK32x-STM3210B-EVAL-MB459-Shinano.stmc
- under Drive Management I changed the sensor selection to quadratur encoder
- exported the settings to System & Drive Params
- I compiled with IAR batch command
my problem is that the motor dont start correctly, i often got a overcurrent fault.
if its start it immediately stops.
if i rotate the motor by hand, the measured speed seems to be correct..
what do i wrong? the hall sensor doesnt work also. the sensorless control work as expected.
thanks
