Mohamed Elfarissi
LSM9DS1 magnetometer calibration(Heading calculation)
Discussion created by Mohamed Elfarissi on Aug 23, 2017
Latest reply on Nov 10, 2017 by Dmitrij Gendler
Hello Forum and ST support,
I am using LSM9DS1 IMU sensor, and In the datasheet, they've mentioned that LSM9DS1 Magnetometers are factory calibrated, but when I calculate the heading and I compare it with a compass App I don't get the same value or even an approached one.
I am using a SparkFun LSM9DS1 library which contains a magnetometer calibration function.
What do you suggest to solve this problem?  Is there any process to follow in order to calibrate LSM9DS1 magnetometer before using it?
Here are the results that I got :
Thank you in advance.
