STM8L Flash Programming
Question asked by Han JaeSeong on Aug 22, 2017
Latest reply on Aug 22, 2017 by Maxime TEISSIER
I use STM8L152R8..
I test flash programming... But, now some problem exists...
Byte programming and word programming is no problem.
But, i use block programming then CPU halted.....
#pragma location = "FLASH_CODE"
void Mem_ProgramBlock(u16 BlockNum, const u8 *Buffer)
u16 Count = 0;
u32 StartAddress = 0;
/* Set Start address wich refers to mem_type */
StartAddress = FLASH_PROGRAM_START_PHYSICAL_ADDRESS;
/* Point to the first block address */
StartAddress = StartAddress + ((u32)BlockNum * FLASH_BLOCK_SIZE);
/* Standard programming mode */
FLASH->CR2 |= (u8)0x01;
/* Copy data bytes from RAM to FLASH memory */
for (Count = 0; Count < FLASH_BLOCK_SIZE; Count++)
*((PointerAttr u8*)StartAddress + Count) = ((u8)(Buffer[Count]));     <= Halted
I use memory.... I unlock cpu before this function.... as below
FLASH->CR1 = 0; // Standard programming Time (EEPM, WAITM, IE Clear)
FLASH->PUKR = FLASH_RASS_KEY1; // Unlock Flash Data
FLASH->PUKR = FLASH_RASS_KEY2;
while ((FLASH->IAPSR & FLASH_IAPSR_PUL) == 0);
I did not find out some bug......
Always  CPU halted in flash programming functioin...
Please help me..
