I2C stuck when SPI enabled
Question asked by Vincenzo N on Aug 7, 2017
Latest reply on Aug 9, 2017 by Vincenzo N
Hello, I have the following problem:
I have a I2C communication routine that takes about 2ms to be executed.
After I do the first read/write operation on a SPI peripheral, the same routine takes 250ms the first time, than it stops working becaus isDeviceBusy always fails.
If I call __HAL_SPI_DISABLE(&hspi) after using SPI, the I2C routine starts working again as before (takes 2ms again and isDeviceBusy does not fail).
So, summarizing:
init_all()
i2c_routine() // Takes 2ms
spi_routine() //
i2c_routine() // Takes 250ms
i2c_routine() // Stucks
init_all()
init_all()
spi_routine()
It seems to be a weird behaviour to me. I've tried a lot of things in the last 2 days, but I cannot understand the cause. May somebody more experienced tell me what's going on? Thank you!
The device is the STM32 Nucleo for L4 series (STM32L432KCU6). I'm using STM32CubeMX and System Workbench for Stm32.
I also attach the pin configuration:
