Eli Aaron
STM32 with SD Card and FatFs using CubeMX – Write error and write speed - Solution
Discussion created by Eli Aaron on Jul 31, 2017
Latest reply on Oct 23, 2017 by sameena shaikh
Description of two problems and solutions:
problems 1: Random write errors
Solution: Configuring SD Card + DMA with CubeMX and modifying the code so FatFs will use DMA (CubeMX will not override the changes)
problems 2: Increasing write time - The more files written, the more time it will take to write the next file
Solution: Using a small number of files (big files)
