USB CDC how to receive values without transmitting
Question asked by zaid shakil on Jul 26, 2017
Latest reply on Oct 3, 2017 by Vangelis Fortounas
Hello Everyone,
I am writing this code where I want my string of values to get displayed on a terminal automatically and I dont have to transmit anything. But I dont seem to succeed. I have to transmit something in order for the terminal to receive values in hex.
Please help me edit my code
Main:
//VCP
volatile uint8_t DataToSend[64];
volatile uint8_t NoOfBytesToSend = 10;
/* USER CODE END PV */
while (1) {
HAL_Delay(1000);
HAL_GPIO_TogglePin(LD6_GPIO_Port, LD6_Pin);
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
DataToSend[0] = 0x11;
DataToSend[5] = 0x22;
DataToSend[6] = sensors.gp2y0a60szlf_distance_cm;
DataToSend[9] = 0x0A;
//sensors_disable();
HAL_Delay(100);
my usb_cdc_if:
* @file : usbd_cdc_if.c
* @brief :
* This notice applies to any and all portions of this file
* that are not between comment pairs USER CODE BEGIN and
* USER CODE END. Other portions of this file, whether
* inserted by the user or by software development tools
* are owned by their respective copyright owners.
* Copyright (c) 2017 STMicroelectronics International N.V.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted, provided that the following conditions are met:
* 1. Redistribution of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of other
* contributors to this software may be used to endorse or promote products
* derived from this software without specific written permission.
* 4. This software, including modifications and/or derivative works of this
* software, must execute solely and exclusively on microcontroller or
* microprocessor devices manufactured by or for STMicroelectronics.
* 5. Redistribution and use of this software other than as permitted under
* this license is void and will automatically terminate your rights under
* this license.
* THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
* RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
* SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "usbd_cdc_if.h"
/* USER CODE BEGIN INCLUDE */
/* USER CODE END INCLUDE */
/** @addtogroup STM32_USB_OTG_DEVICE_LIBRARY
/** @defgroup USBD_CDC
* @brief usbd core module
/** @defgroup USBD_CDC_Private_TypesDefinitions
/* USER CODE BEGIN PRIVATE_TYPES */
/* USER CODE END PRIVATE_TYPES */
/** @defgroup USBD_CDC_Private_Defines
/* USER CODE BEGIN PRIVATE_DEFINES */
/* Define size for the receive and transmit buffer over CDC */
/* It's up to user to redefine and/or remove those define */
#define APP_RX_DATA_SIZE 4
#define APP_TX_DATA_SIZE 4
/* USER CODE END PRIVATE_DEFINES */
/** @defgroup USBD_CDC_Private_Macros
/* USER CODE BEGIN PRIVATE_MACRO */
/* USER CODE END PRIVATE_MACRO */
/** @defgroup USBD_CDC_Private_Variables
/* Create buffer for reception and transmission */
/* Received Data over USB are stored in this buffer */
uint8_t UserRxBufferFS[APP_RX_DATA_SIZE];
/* Send Data over USB CDC are stored in this buffer */
uint8_t UserTxBufferFS[APP_TX_DATA_SIZE];
/* USER CODE BEGIN PRIVATE_VARIABLES */
//VCP
extern volatile uint8_t DataToSend[];
extern volatile uint8_t NoOfBytesToSend;
/* USER CODE END PRIVATE_VARIABLES */
/** @defgroup USBD_CDC_IF_Exported_Variables
extern USBD_HandleTypeDef hUsbDeviceFS;
/* USER CODE BEGIN EXPORTED_VARIABLES */
/* USER CODE END EXPORTED_VARIABLES */
/** @defgroup USBD_CDC_Private_FunctionPrototypes
static int8_t CDC_Init_FS(void);
static int8_t CDC_DeInit_FS(void);
static int8_t CDC_Control_FS(uint8_t cmd, uint8_t* pbuf, uint16_t length);
static int8_t CDC_Receive_FS(uint8_t* pbuf, uint32_t *Len);
/* USER CODE BEGIN PRIVATE_FUNCTIONS_DECLARATION */
/* USER CODE END PRIVATE_FUNCTIONS_DECLARATION */
USBD_CDC_ItfTypeDef USBD_Interface_fops_FS = { CDC_Init_FS, CDC_DeInit_FS,
CDC_Control_FS, CDC_Receive_FS };
* @brief CDC_Init_FS
* Initializes the CDC media low layer over the FS USB IP
* @param None
* @retval Result of the operation: USBD_OK if all operations are OK else USBD_FAIL
static int8_t CDC_Init_FS(void) {
/* Set Application Buffers */
USBD_CDC_SetTxBuffer(&hUsbDeviceFS, UserTxBufferFS, 0);
USBD_CDC_SetRxBuffer(&hUsbDeviceFS, UserRxBufferFS);
return (USBD_OK);
/* USER CODE END 3 */
* @brief CDC_DeInit_FS
* DeInitializes the CDC media low layer
* @param None
static int8_t CDC_DeInit_FS(void) {
/* USER CODE BEGIN 4 */
return (USBD_OK);
/* USER CODE END 4 */
* @brief CDC_Control_FS
* Manage the CDC class requests
* @param cmd: Command code
* @param pbuf: Buffer containing command data (request parameters)
* @param length: Number of data to be sent (in bytes)
static int8_t CDC_Control_FS(uint8_t cmd, uint8_t* pbuf, uint16_t length) {
/* USER CODE BEGIN 5 */
switch (cmd) {
case CDC_SEND_ENCAPSULATED_COMMAND:
break;
case CDC_GET_ENCAPSULATED_RESPONSE:
break;
case CDC_SET_COMM_FEATURE:
break;
case CDC_GET_COMM_FEATURE:
break;
case CDC_CLEAR_COMM_FEATURE:
break;
/* Line Coding Structure */
/* Offset | Field | Size | Value | Description */
/* 0 | dwDTERate | 4 | Number |Data terminal rate, in bits per second*/
/* 4 | bCharFormat | 1 | Number | Stop bits */
/* 0 - 1 Stop bit */
/* 1 - 1.5 Stop bits */
/* 2 - 2 Stop bits */
/* 5 | bParityType | 1 | Number | Parity */
/* 0 - None */
/* 1 - Odd */
/* 2 - Even */
/* 3 - Mark */
/* 4 - Space */
/* 6 | bDataBits | 1 | Number Data bits (5, 6, 7, 8 or 16). */
case CDC_SET_LINE_CODING:
break;
case CDC_GET_LINE_CODING:
break;
case CDC_SET_CONTROL_LINE_STATE:
break;
case CDC_SEND_BREAK:
break;
default:
break;
return (USBD_OK);
/* USER CODE END 5 */
* @brief CDC_Receive_FS
* Data received over USB OUT endpoint are sent over CDC interface
* through this function.
* @note
* This function will block any OUT packet reception on USB endpoint
* untill exiting this function. If you exit this function before transfer
* is complete on CDC interface (ie. using DMA controller) it will result
* in receiving more data while previous ones are still not sent.
* @param Buf: Buffer of data to be received
* @param Len: Number of data received (in bytes)
static int8_t CDC_Receive_FS(uint8_t* Buf, uint32_t *Len) {
/* USER CODE BEGIN 6 */
//if (Buf[0] != 0x41)
CDC_Transmit_FS(DataToSend, NoOfBytesToSend);
//CDC_Transmit_FS((uint8_t*)"\n",1);
//USBD_CDC_SetRxBuffer(&hUsbDeviceFS, &Buf[0]);
USBD_CDC_ReceivePacket(&hUsbDeviceFS);
return (USBD_OK);
/* USER CODE END 6 */
* @brief CDC_Transmit_FS
* Data send over USB IN endpoint are sent over CDC interface
* @note
* @param Buf: Buffer of data to be send
* @param Len: Number of data to be send (in bytes)
* @retval Result of the operation: USBD_OK if all operations are OK else USBD_FAIL or USBD_BUSY
uint8_t CDC_Transmit_FS(uint8_t* Buf, uint16_t Len) {
uint8_t result = USBD_OK;
/* USER CODE BEGIN 7 */
//USBD_CDC_HandleTypeDef *hcdc =
// (USBD_CDC_HandleTypeDef*) hUsbDeviceFS.pClassData;
//if (hcdc->TxState != 0) {
//return USBD_BUSY;
USBD_CDC_SetTxBuffer(&hUsbDeviceFS, Buf, Len);
result = USBD_CDC_TransmitPacket(&hUsbDeviceFS);
/* USER CODE END 7 */
return result;
/* USER CODE BEGIN PRIVATE_FUNCTIONS_IMPLEMENTATION */
/* USER CODE END PRIVATE_FUNCTIONS_IMPLEMENTATION */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Hope to hear soon.
