STM32L072_Discovery
Question asked by Prasanth Velliyangiri on Jul 17, 2017
Latest reply on Jul 18, 2017 by Amel N
Hi Support Team
I am using STM32L072_Discovery kit..
In cubeMx - Boards i am not able to see my board , i want to check power consumption for this board.
Now i am manually checking using multimeter (i am using I2C , RTC , USART) enable standby mode and i put unused GPIO in Analog mode
consumption is
STANDBY  => 1.14 ua
RUN          =>  635ua , RUN mode consumption  is huge , how can i reduce further...
Below cubeMx generated system clock config
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit;
/**Configure the main internal regulator output voltage
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.MSIState = RCC_MSI_ON;
RCC_OscInitStruct.MSICalibrationValue = 0;
RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_5;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART2|RCC_PERIPHCLK_I2C1
|RCC_PERIPHCLK_RTC;
PeriphClkInit.Usart2ClockSelection = RCC_USART2CLKSOURCE_PCLK1;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
/**Configure the Systick interrupt time
Q2 : if i am using 240mAh battery , how to calculate battery life cycle , please provide some formula
STANDBY  => 1.14 ua
RUN          =>  635ua (every 15 min device will wake up read i2c data store and go to sleep)
