STMF105RC CAN1 can't receive Message sometime on low CANID
Question asked by shen songyan on Jul 18, 2017
Latest reply on Jul 18, 2017 by Jeroen3
Hi everyone,
I use CAN interrupt to receive CAN message, the CAN ID is 0x500 that is lower than other CAN IDs what I received.
but this CAN message can not received frequency. sometimes it will loss.
So I don't know where is wrong. could you help me?
thanks!
for My Initial code & CAN interrupt code is below:
u8 CAN_Mode_Init(u8 tsjw,u8 tbs2,u8 tbs1,u16 brp,u8 mode)
   CAN_InitTypeDef            CAN_InitStructure;
   CAN_FilterInitTypeDef      CAN_FilterInitStructure;
   /*init can */
   CAN_InitStructure.CAN_TTCM=DISABLE;
   CAN_InitStructure.CAN_ABOM=ENABLE;
   CAN_InitStructure.CAN_AWUM=DISABLE;
   CAN_InitStructure.CAN_NART=DISABLE;
   CAN_InitStructure.CAN_RFLM=DISABLE;
   CAN_InitStructure.CAN_TXFP=DISABLE;
   CAN_InitStructure.CAN_Mode= mode;
   /*set baud rate*/
   CAN_InitStructure.CAN_SJW=tsjw;
   CAN_InitStructure.CAN_BS1=tbs1;
   CAN_InitStructure.CAN_BS2=tbs2;
   CAN_InitStructure.CAN_Prescaler=brp;
   CAN_Init(CAN1, &CAN_InitStructure);
   /*init filter/mask*/
   CAN_FilterInitStructure.CAN_FilterNumber=0;    //filter 0
   CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdList;     //mask mode
   CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_16bit;     //filter scale
   /*id list is id1 id2 id3 id4*/
   CAN_FilterInitStructure.CAN_FilterIdHigh=VCU_HMI_ID1<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterIdLow=VCU_HMI_ID2<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdHigh=VCU_HMI_ID3<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdLow=VCU_HMI_ID4<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0;
   CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
   CAN_FilterInit(&CAN_FilterInitStructure);
   /*id list is id5 id6 id7 */
   CAN_FilterInitStructure.CAN_FilterNumber=1;    //filter 1
   CAN_FilterInitStructure.CAN_FilterIdHigh=VCU_HMI_ID5<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterIdLow=VCU_HMI_ID6<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdHigh=VCU_HMI_ID7<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdLow=VCU_HMI_DIAGNOSE<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterNumber=2;    //filter 2
   CAN_FilterInitStructure.CAN_FilterIdHigh=ABS_INFO<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterIdLow=VCU_HMI_ID8<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdHigh=UDS_TESTER_ID<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdLow=UDS_VCU_ID<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterNumber=3;    //filter 3
   CAN_FilterInitStructure.CAN_FilterIdHigh=NETWORK_STATE<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterIdLow=BMS_VCU_07<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdHigh=ENCRYPTION_VCU_HMI<<FILTER_MASK_STDID_SHIFT;
   CAN_FilterInitStructure.CAN_FilterMaskIdLow=NULL<<FILTER_MASK_STDID_SHIFT;
   return 0;
Function: CanIsrRx0_0
Description: recv intterrupt
Called By: N A
Input: recv message
Output: can data & can id
Return: NA
Others: NA
void CanIsrRx0_0(void)
   CanRxMsg rxMessage;
   if(CAN_GetITStatus(CAN1,CAN_IT_FF0))//fifo full
      CAN_ClearITPendingBit(CAN1,CAN_IT_FF0);//clear fifo full
   else if(CAN_GetITStatus(CAN1,CAN_IT_FOV0))//overflow flag
      CAN_ClearITPendingBit(CAN1,CAN_IT_FOV0);//clear overflow
   else
      CAN_Receive(CAN1,CAN_FIFO0, &rxMessage);
      CAN_ClearITPendingBit(CAN1,CAN_IT_FMP0);
      CAN_FIFORelease(CAN1,CAN_FIFO0);
      /*rx process*/
      CanMessageSendRxQueue(&rxMessage);
