STMF746 CAN1 Setup
Question asked by David Picazzo on Jul 10, 2017
Good Afternoon! I need help configuring an STM32F746 nucleo board for use with CAN1.  I am using PCAN view to send CAN messages at 250 kBit/s, and CubeMx to generate the initialization code. I am sort of new to this and I am not sure how i should configure the System Clock or what parameters I should use for the Bit Timings in the CAN 1 Configuration. This is the Bit timing calculator I am using but I am unsure of what clock rate I should use: CAN Bit Time Calculation. I am trying to migrate working code from a STM32F207 Board with the following Clock Configuration Settings:
Thank you for taking the time to help!
