STM32F103C8 DSP Library problem
Question asked by Mucit23 on Jun 19, 2017
Latest reply on Jun 23, 2017 by AvaTar
Hello there
Can I compile the DSP library with STM32F103C8 device. I would like to import FFT using DSP library with this chip. But I get many errors when I compile the library.
compiling main.c...
.\Library\DSP Library\Include\core_cm3.h(74): warning: #47-D: incompatible redefinition of macro "__CM3_CMSIS_VERSION_MAIN" (declared at line 84 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __CM3_CMSIS_VERSION_MAIN (0x04U) /*!< [31:16] CMSIS HAL main version */
.\Library\DSP Library\Include\core_cm3.h(79): warning: #47-D: incompatible redefinition of macro "__CORTEX_M" (declared at line 88 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __CORTEX_M (0x03U) /*!< Cortex-M Core */
.\Library\DSP Library\Include\cmsis_armcc.h(57): error: #247: function "__get_CONTROL" has already been defined
__STATIC_INLINE uint32_t __get_CONTROL(void)
.\Library\DSP Library\Include\cmsis_armcc.h(69): error: #247: function "__set_CONTROL" has already been defined
__STATIC_INLINE void __set_CONTROL(uint32_t control)
.\Library\DSP Library\Include\cmsis_armcc.h(165): error: #247: function "__get_PRIMASK" has already been defined
__STATIC_INLINE uint32_t __get_PRIMASK(void)
.\Library\DSP Library\Include\cmsis_armcc.h(177): error: #247: function "__set_PRIMASK" has already been defined
__STATIC_INLINE void __set_PRIMASK(uint32_t priMask)
.\Library\DSP Library\Include\cmsis_armcc.h(207): error: #247: function "__get_BASEPRI" has already been defined
__STATIC_INLINE uint32_t __get_BASEPRI(void)
.\Library\DSP Library\Include\cmsis_armcc.h(219): error: #247: function "__set_BASEPRI" has already been defined
__STATIC_INLINE void __set_BASEPRI(uint32_t basePri)
.\Library\DSP Library\Include\cmsis_armcc.h(244): error: #247: function "__get_FAULTMASK" has already been defined
__STATIC_INLINE uint32_t __get_FAULTMASK(void)
.\Library\DSP Library\Include\cmsis_armcc.h(256): error: #247: function "__set_FAULTMASK" has already been defined
__STATIC_INLINE void __set_FAULTMASK(uint32_t faultMask)
.\Library\DSP Library\Include\cmsis_armcc.h(344): warning: #47-D: incompatible redefinition of macro "__ISB" (declared at line 772 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __ISB() do {\
.\Library\DSP Library\Include\cmsis_armcc.h(355): warning: #47-D: incompatible redefinition of macro "__DSB" (declared at line 773 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __DSB() do {\
.\Library\DSP Library\Include\cmsis_armcc.h(366): warning: #47-D: incompatible redefinition of macro "__DMB" (declared at line 774 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __DMB() do {\
.\Library\DSP Library\Include\cmsis_armcc.h(388): error: #147-D: declaration is incompatible with "uint32_t __REV16(uint16_t)" (declared at line 838 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
__attribute__((section(".rev16_text"))) __STATIC_INLINE __ASM uint32_t __REV16(uint32_t value)
.\Library\DSP Library\Include\cmsis_armcc.h(402): error: #147-D: declaration is incompatible with "int32_t __REVSH(int16_t)" (declared at line 848 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
__attribute__((section(".revsh_text"))) __STATIC_INLINE __ASM int32_t __REVSH(int32_t value)
.\Library\DSP Library\Include\cmsis_armcc.h(477): warning: #47-D: incompatible redefinition of macro "__LDREXB" (declared at line 777 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __LDREXB(ptr) _Pragma("push") _Pragma("diag_suppress 3731") ((uint8_t ) __ldrex(ptr)) _Pragma("pop")
.\Library\DSP Library\Include\cmsis_armcc.h(490): warning: #47-D: incompatible redefinition of macro "__LDREXH" (declared at line 778 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __LDREXH(ptr) _Pragma("push") _Pragma("diag_suppress 3731") ((uint16_t) __ldrex(ptr)) _Pragma("pop")
.\Library\DSP Library\Include\cmsis_armcc.h(503): warning: #47-D: incompatible redefinition of macro "__LDREXW" (declared at line 779 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __LDREXW(ptr) _Pragma("push") _Pragma("diag_suppress 3731") ((uint32_t ) __ldrex(ptr)) _Pragma("pop")
.\Library\DSP Library\Include\cmsis_armcc.h(518): warning: #47-D: incompatible redefinition of macro "__STREXB" (declared at line 780 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __STREXB(value, ptr) _Pragma("push") _Pragma("diag_suppress 3731") __strex(value, ptr) _Pragma("pop")
.\Library\DSP Library\Include\cmsis_armcc.h(533): warning: #47-D: incompatible redefinition of macro "__STREXH" (declared at line 781 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __STREXH(value, ptr) _Pragma("push") _Pragma("diag_suppress 3731") __strex(value, ptr) _Pragma("pop")
.\Library\DSP Library\Include\cmsis_armcc.h(548): warning: #47-D: incompatible redefinition of macro "__STREXW" (declared at line 782 of ".\Library\CMSIS\CM3\CoreSupport\core_cm3.h")
#define __STREXW(value, ptr) _Pragma("push") _Pragma("diag_suppress 3731") __strex(value, ptr) _Pragma("pop")
User\main.c: 13 warnings, 10 errors
".\Objects\FFT.axf" - 10 Error(s), 11 Warning(s).
I added the project. What could be the problem?
