How to send data to OP-AMP and get the value
Question asked by Nicolas Bousmanne on May 31, 2017
Latest reply on Jun 2, 2017 by Zhitai Liu
I'm still trying to continue the programmation of my STM32F405 board and I have (again) a little problem. I use a OP-AMP to compare 2 signals by sending him a integer. The return value is always the same even if I change the initial integer and I dont understand why...
I hope this is understandable.
Can you explain me what's wrong in my code or eventually show me some documentation ?
void gpio_initialize()
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    GPIO_InitTypeDef GPIO_initStruct_PA_an2;
    GPIO_initStruct_PA_an2.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
    GPIO_initStruct_PA_an2.GPIO_Mode = GPIO_Mode_AN;
    GPIO_initStruct_PA_an2.GPIO_OType = GPIO_OType_PP;
    GPIO_initStruct_PA_an2.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_initStruct_PA_an2.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_Init(GPIOA, &GPIO_initStruct_PA_an2);
void dac_initialize()
    DAC_InitTypeDef DAC_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
    DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software;
    DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;// DAC_WaveGeneration_Triangle;
    DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
    //DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_TriangleAmplitude_4095;
    DAC_Init(DAC_Channel_1, &DAC_InitStructure);
    DAC_Init(DAC_Channel_2, &DAC_InitStructure);
    DAC_Cmd(DAC_Channel_1, ENABLE);
    DAC_Cmd(DAC_Channel_2, ENABLE);
    DAC_SoftwareTriggerCmd(DAC_Channel_1, ENABLE);
    DAC_SoftwareTriggerCmd(DAC_Channel_2, ENABLE);
void adc_initialize()
    ADC_InitTypeDef ADC_init_struct12b;
    //Clock configuration
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    //ADC structure configuration
    ADC_DeInit();
    ADC_init_struct12b.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_init_struct12b.ADC_Resolution = ADC_Resolution_12b;
    ADC_init_struct12b.ADC_ContinuousConvMode = ENABLE;
    ADC_init_struct12b.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
    ADC_init_struct12b.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
    ADC_init_struct12b.ADC_NbrOfConversion = 1;
    ADC_init_struct12b.ADC_ScanConvMode = DISABLE;
    ADC_Init(ADC1, &ADC_init_struct12b);//Initialize ADC with the previous configuration
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_3Cycles);
    ADC_Cmd(ADC1, ENABLE);
int adc_convert_sence()
    ADC_SoftwareStartConv(ADC1);
    while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));
    return ADC_GetConversionValue(ADC1);
int main(void)
    gpio_initialize();
    adc_initialize();
    dac_initialize();
    systickInit(1000);
    DAC_SetChannel2Data(DAC_Align_12b_R, 2048);
    while (1)
        DAC_SetChannel1Data(DAC_Align_12b_R, 0);
        delay_ms(20);
        resultSence = adc_convert_sence();
        printf("%d / ", resultSence);
        DAC_SetChannel1Data(DAC_Align_12b_R, 10);
        delay_ms(20);
        DAC_SetChannel1Data(DAC_Align_12b_R, 500);
        delay_ms(20);
Thanking you in advance,
Nicolas-
