Bug in USB Host Library? Isochronous data receive
Question asked by frerichs.dirk on May 8, 2017
Latest reply on Mar 7, 2018 by Kevin Carney
Hi
I think it is a bug...
Problem:
Isochronous data Receive from  USB Device with ST USB Host library.
- > no example or projects in internet
So i tried to get data from USB Webcam.
But i  didn't get an USBH_URB_DONE event or other flag
i added following lines in function:
static void HCD_HC_IN_IRQHandler   (HCD_HandleTypeDef *hhcd, uint8_t chnum)
    if ((hhcd->hc[chnum].ep_type == EP_TYPE_CTRL)||
        (hhcd->hc[chnum].ep_type == EP_TYPE_BULK))
      __HAL_HCD_UNMASK_HALT_HC_INT(chnum);
      USB_HC_Halt(hhcd->Instance, chnum);
      __HAL_HCD_CLEAR_HC_INT(chnum, USB_OTG_HCINT_NAK);
    else if((hhcd->hc[chnum].ep_type == EP_TYPE_INTR)||
            (hhcd->hc[chnum].ep_type == EP_TYPE_ISOC ))
      USBx_HC(chnum)->HCCHAR |= USB_OTG_HCCHAR_ODDFRM;
      hhcd->hc[chnum].urb_state = URB_DONE;
      HAL_HCD_HC_NotifyURBChange_Callback(hhcd, chnum, hhcd->hc[chnum].urb_state);
    hhcd->hc[chnum].toggle_in ^= 1;
line   (hhcd->hc[chnum].ep_type == EP_TYPE_ISOC )) added to catch URB EVENT
example for receive isochronous  data :
    case VIDEO_STREAM_START:
            USBH_IsocReceiveData( phost ,
                framebuffer ,
                pVideo->EpVideoStream.wMaxPacketSize,
                pVideo->EpVideoStream.bPipe );
            pVideo->StreamState = VIDEO_STREAM_PLAY;
            osMessagePut ( phost->os_event, USBH_URB_EVENT , 0);
            break;
        case VIDEO_STREAM_PLAY:
            if((USBH_LL_GetURBState(phost , pVideo->EpVideoStream.bPipe) == USBH_URB_DONE)&&
                ((phost->Timer-pVideo->EpVideoStream.wTimer) >= pVideo->EpVideoStream.bInterval)){
                pVideo->EpVideoStream.wTimer = phost->Timer;
                uint32_t  rxlen = USBH_LL_GetLastXferSize  (phost,   pVideo->EpVideoStream.bPipe ) ;
                if( rxlen ){
                      framebuffer ,
            break;
