powerstep01
Question asked by sen.lin.001 on May 7, 2017
Latest reply on May 12, 2017 by Enrico Poli
An arm cortex-M0 MCU is adopted to drive the powetstep01.
The initialization of SPI is done including CS, SDO, SDI, CK,BUSY, STBY.
Here is the problem, I want the step motor run, so I write this:
CS=low;//chip select
SPI1_TX0 = param;//param=0xFF50, since the address of the run command is 0101000DIR, and FF represents speed
SPI1_CNTRL |= GO_BUSY;//start the transmit
delay;
CS=high;
The powerstep01 did not work. Is this the right way?
Or what else should be done  before sending commands(SPI has been initialized already)?
Thank you very much!
