STM32L496G-Discovery Demonstration Example
Question asked by Alptigin SAKI on May 5, 2017
Latest reply on Dec 6, 2017 by Kyle Wang
Hi my name is Alptigin SAKI,
I have a question about STM32L496G-Discovery Demonstration Example in IAR. I am using IAR v8.11 when I opened the project and click rebuild all I found  couples error about "core_cmFunc.h" not found. I opened same example with Keil there is no problem I find the library and add to IAR. I think you can check and maybe ugrade new version of STM32Cube_FW_L4_1.7.xx . Now I am asking my question, when I rebuild all and debug the code I got 3 warnings and 1 error.
Warnings:
1-)Fri May 05, 2017 22:26:42: Flash download warning: 1233776 out of 1233776 bytes from data record CODE:[0x90000000,0x9012D36F] will not be flashed
2-)Fri May 05, 2017 22:26:42: Flash download warning: 3112924 out of 3112924 bytes from data record CODE:[0x90140000,0x90437FDB] will not be flashed
3-)Fri May 05, 2017 22:26:42: Flash download warning: 3462180 out of 3462180 bytes from data record CODE:[0x9049A000,0x907E7423] will not be flashed
Error:
Fri May 05, 2017 22:26:42: There were warnings while generating flash loader input.
Can you tell me why I got these errors??
Thanks..
A.SAKI
