STM32F0 ADC DMA Assistance
Question asked by Placzek.Eric.001 on Apr 14, 2017
Latest reply on Apr 15, 2017 by Jinhui Lin
Hello All,
Hoping someone can help me understand the ADC DMA via ST's HAL. I haven't been able to locate the information I need to understand how it works or what I have read still doesn't give me what I need so if someone refers me to the proper doc I'll take a RTFM response if it clearly gives me the understanding I am looking for.
Essentially I have 4 ADC's (in 12 bit resolution mode) and I am trying capture that data and convert it (ie temp, moisture, ect..). Trying to understand how the API works for the DMA conversion and how my 4 ADC channels align in my assigned pointer. Below outlines what I currently have set up, and highlighted in red text is where my confusion is.
I am using the STM32F072RB custom board design, used CubeMX to set up the ADC:
Below is called in my main function:
if (HAL_ADC_Start_DMA(&hadc, (uint32_t*)ADC1ConvertedValues, 1024) != HAL_OK)
  return 0;
Below is in my while loop:
sprintf((char *)str, "ADC Val: %d %d %d %d\r\n", ADC1ConvertedValues[0], ADC1ConvertedValues[1], ADC1ConvertedValues[2], ADC1ConvertedValues[3]); // Want my 4 ADC channels to print the individual ADC value read.
  len = strlen((char *)str);
  HAL_UART_Transmit(&huart2, str, len, 1000);
Debugger Watch result:
/* ADC init function */
static void MX_ADC_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = ENABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
    /**Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_4;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_10;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_11;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_12;
    Error_Handler();
