Core becomes Inactive
Question asked by Santhamurthy R on Apr 12, 2017
Latest reply on Apr 13, 2017 by Santhamurthy R
Hello All,
I am using SPC560B54L5 discovery board and SPC5studio version 5.2.1 along with UDE 4.2 version.The setup was working fine till this time. suddenly it started giving issues.
Initially when I connect the board the PLS driver is getting detected in device manager and I can able to open the UDE and load the code. But within 2 or 3 minutes the core is getting inactive later if I check the Device manager PLS driver was unmounted. Again If I disconnect and reconnect the hardware things works fine for 2 minutes and the problem occurs again.
I tried reinstalling the UDE/PLS and USB drivers but the issue keeps repeating.
Kindly provide your suggestion is resolving the issue
Thanks in Advance,
With Regards,
R.santhamurthy
