Andrei Chichak
A suggestion for the CubeMX team...
Discussion created by Andrei Chichak on Mar 29, 2017
Latest reply on Mar 31, 2017 by Andrei Chichak
Here's a suggestion, in Cube, you give a description area that explains what the parameters mean in the Configuration tab. How about putting some documentation in there rather than simply reiterating the parameter name and the values that it can take?
I know the parameter name, I had to click on it. I know the values, I can click on them too.
As for the semantics of parameters, that is not always apparent. If you were to explain what the parameter does, that would be useful. I realize it is in the manual, but I'm lazy. This would be a great opportunity to enhance my user experience.
Thanks in advance,
Andrei from The Great White North
(as seen on the embedded.fm podcast and blog)
