Babichenko.Yevhenii
STM32CubeMX: GCC linker files are not copied when using "Other toolchain"
Discussion created by Babichenko.Yevhenii on Mar 27, 2017
Latest reply on Mar 28, 2017 by AvaTar
I am trying to use STM32CubeMX with "Toolchain" set to "Other toolchains (GPDSC)". But with that setting Cube doesn't copy linker files for GNU Compiler. Yes, they can be found at the firmware package location, but I'd like those files to be copied to the project location as for IAR toolchain. Thank you in advance for your consideration.
