Problem with STMicroelectronics GNU GCC compiler
Question asked by SAYGILI.Cengizhan on Mar 23, 2017
Latest reply on Oct 12, 2017 by Erwan Y
Below partial code of our project.
typedef struct
    U_16 no;
    U_8 duration;
    BuzzerSounds buzzerSong;
    priorityLevels priority;
    TBOOL buzzerPeriodic;
    TBOOL isPlayed;
}event;
typedef struct
    U_32 canID;
    U_64 canData;
}canMSG;
typedef enum
    PRIORITY_BLOCKER = 0,
    PRIORITY_HIGH,
    PRIORITY_MID,
    PRIORITY_LOW,
    PRIORITY_TRIVIAL
}priorityLevels;
event eventRecord = {0,0,B_IDLE,255,0,0};
//This red part successfully compiled but not works.
static canMSG msg;
msg.canID   = CAN_ID_SETUPREAD | eventDeviceID;
msg.canData = (0x04) + (971uLL << 8) + (((U_64)eventRecord.no) << 32) + (((U_64)eventRecord.duration) << 48) + (((U_64)eventRecord.priority) << 56);
can0SendMessage(msg);
//When i changed red part of code like this, it works.
static canMSG msg;
msg.canData = (0x04);
msg.canData += (971uLL << 8);
msg.canData += (((U_64)eventRecord.no) << 32);
msg.canData += (((U_64)eventRecord.duration) << 48);
msg.canData += (((U_64)eventRecord.priority) << 56);
//Also when i changed red part of code like this, it works again
static canMSG msg;
msg.canData = (0x04) + (971uLL << 8) + (((U_64)eventRecord.no) << 32) + (((U_64)eventRecord.duration) << 48);
//I think problem is enum part of code. (((U_64)eventRecord.priority) << 56)
I compile this project with Hightec GCC 4.6.3 toolchain, there is no problem. Red part works normally.
