switch from async mode ( WIND) to normal AT CMD in UART stream
Question asked by Mikael.Elharrar on Mar 13, 2017
Latest reply on Mar 15, 2017 by Mikael.Elharrar
Hi guys,
I'm using SPWF001 and wanted to write my parser since the host MCU is not STM32 (so I cant use the example).
Simple question: If the module is in the middle of +WIND:xx:yyy, and I send an AT Command, is the current string is cut or the module will finish the string and will respond to AT Command.
In other words, is this possible:
<cr><lf>+WIND:xx:yyy<cr><lf>OK<cr><lf>yyyyyyy<cr><lf>
or it will always be:
<cr><lf>+WIND:xx:yyyyyyyyyy<cr><lf><cr><lf>OK<cr><lf>
THANKS YOU
