Clock and PLL initialization
Question asked by 123.abc on Mar 3, 2017
Latest reply on Mar 10, 2017 by Luigi Zambrano
Hi, I am trying to setup the clocks/PLL on the SPC570S40E1 microcontroller. I would like use the PLL0 as the system clock.
Here is my configuration:
AC3 SC  -> 16Mhz IRSOC
AC2 SC  -> PLL1
PLL0 Settings:
PREDIV      -> 2
MFD            -> 80
RFDPHI      -> 10
RFDPHI1    -> 10
PLL1 Settings:
MFD             ->18
RFDPHI       ->8
With the above settings, I get the following clk rates.
Here is my initialization code. Its getting stuck in the while loop waiting for PLL0 to lock. I am following the PLLs initialization procedure that is recommended in the reference manual.
void spc_clock_init(void) {
  /* Waiting for IRC stabilization before attempting anything else.*/
  while (MC_ME.GS.B.S_IRC == 0U) {
#if (SPC5_NO_INIT == FALSE)
#if SPC5_DISABLE_WATCHDOG
  /* SWTs disabled.*/
  SWT_2.SR.R = 0xC520U;
  SWT_2.SR.R = 0xD928U;
  SWT_2.CR.R = 0xFF000002UL;
#endif
  /* The system must be in DRUN mode on entry, if this is not the case then
     it is considered a serious anomaly.*/
  if (MC_ME.GS.B.S_CURRENT_MODE != (uint8_t)SPC5_RUNMODE_DRUN) {
    SPC5_CLOCK_FAILURE_HOOK();
  /* Memory-mapped register definitions incompatible with MISRA rule. */
  /*lint -e10 -e40 -e63*/
  /* Setting the system dividers to their final values.*/
  MC_CGM.SC_DC0.R   = SPC5_CGM_SC_DC0_BITS;
  MC_CGM.SC_DC1.R   = SPC5_CGM_SC_DC1_BITS;
  MC_CGM.SC_DC2.R   = SPC5_CGM_SC_DC2_BITS;
  /* Setting the auxiliary dividers to their final values.*/
  MC_CGM.AC0_DC0.= SPC5_CGM_AC0_DC0_BITS;
  MC_CGM.AC0_DC1.= SPC5_CGM_AC0_DC1_BITS;
  MC_CGM.AC0_DC2.= SPC5_CGM_AC0_DC2_BITS;
  MC_CGM.AC0_DC3.= SPC5_CGM_AC0_DC3_BITS;
  MC_CGM.AC0_DC4.= SPC5_CGM_AC0_DC4_BITS;
  MC_CGM.AC0_DC5.= SPC5_CGM_AC0_DC5_BITS;
  MC_CGM.AC1_DC0.= SPC5_CGM_AC1_DC0_BITS;
  /* Setting the clock selectors to their final sources.*/
  MC_CGM.AC0_SC.R   = SPC5_CGM_AC0_SC_BITS;
  MC_CGM.AC1_SC.R   = SPC5_CGM_AC1_SC_BITS;
  MC_CGM.AC2_SC.R   = SPC5_CGM_AC2_SC_BITS;
  MC_CGM.AC3_SC.R   = SPC5_CGM_AC3_SC_BITS;
  /*lint +e10 +e40 +e63*/
  /* Enables the XOSC in order to check its functionality before proceeding
     with the initialization.*/
  MC_ME.DRUN_MC.R   = SPC5_ME_MC_SYSCLK_IRC | SPC5_ME_MC_IRCON |
                      SPC5_ME_MC_XOSCON | SPC5_ME_MC_FLAON_NORMAL |
                      SPC5_ME_MC_MVRON;
  if (SPCSetRunMode(SPC5_RUNMODE_DRUN) == 0) {
  // PLL0 and PLL1 initialization sequence
  // Program PLL0 Divider Register
  PLLDIG.PLL0DV.R   = SPC5_PLL0_DV_RFDPHI1(SPC5_PLL0_RFDPHI1_VALUE) |
                      SPC5_PLL0_DV_RFDPHI(SPC5_PLL0_RFDPHI_VALUE) |
                      SPC5_PLL0_DV_PREDIV(SPC5_PLL0_PREDIV_VALUE) |
                      SPC5_PLL0_DV_MFD(SPC5_PLL0_MFD_VALUE);
  // Power up PLL0
  MC_ME.DRUN_MC.B.PLL0ON = 1;
  // Poll PLL0SR[LOCK] until it asserts
  while (PLLDIG.PLL0SR.B.LOCK == 0)
  PLLDIG.PLL1CR.R   = 0U;
  // Program PLL1 Divider Register
  PLLDIG.PLL1DV.R   = SPC5_PLL1_DV_RFDPHI(SPC5_PLL1_RFDPHI_VALUE) |
                      SPC5_PLL1_DV_MFD(SPC5_PLL1_MFD_VALUE);
  // Power up PLL1
  MC_ME.DRUN_MC.B.PLL1ON = 1;
  // Poll Pll1SR[LOCK] until it asserts
  while (PLLDIG.PLL1SR.B.LOCK == 0)
  // Engage Normal mode
  PLLDIG.PLL0CR.B.CLKCFG   = 3U;
  PLLDIG.PLL1CR.B.CLKCFG   = 3U;
  /* Switches to DRUN mode (current mode) in order to update the
     settings.*/
  /* Run modes initialization, note writes to the MC registers are verified
     by a protection mechanism, the operation success is verified at the
     end of the sequence.*/
  MC_ME.IS.R        = 8U;                        /* Resetting I_ICONF status.*/
  MC_ME.ME.R        = SPC5_ME_ME_BITS;
  MC_ME.SAFE_MC.R   = SPC5_ME_SAFE_MC_BITS;
  MC_ME.DRUN_MC.R   = SPC5_ME_DRUN_MC_BITS;
  MC_ME.RUN_MC[0].R = SPC5_ME_RUN0_MC_BITS;
  MC_ME.RUN_MC[1].R = SPC5_ME_RUN1_MC_BITS;
  MC_ME.RUN_MC[2].R = SPC5_ME_RUN2_MC_BITS;
  MC_ME.RUN_MC[3].R = SPC5_ME_RUN3_MC_BITS;
  MC_ME.HALT_MC.R   = SPC5_ME_HALT0_MC_BITS;
  MC_ME.STOP_MC.R   = SPC5_ME_STOP0_MC_BITS;
  if ((MC_ME.IS.B.I_ICONF & 1U) == 1U) {
    /* Configuration rejected.*/
  /* Peripherals run and low power modes initialization.*/
  MC_ME.RUN_PC[0].R = SPC5_ME_RUN_PC0_BITS;
  MC_ME.RUN_PC[1].R = SPC5_ME_RUN_PC1_BITS;
  MC_ME.RUN_PC[2].R = SPC5_ME_RUN_PC2_BITS;
  MC_ME.RUN_PC[3].R = SPC5_ME_RUN_PC3_BITS;
  MC_ME.RUN_PC[4].R = SPC5_ME_RUN_PC4_BITS;
  MC_ME.RUN_PC[5].R = SPC5_ME_RUN_PC5_BITS;
  MC_ME.RUN_PC[6].R = SPC5_ME_RUN_PC6_BITS;
  MC_ME.RUN_PC[7].R = SPC5_ME_RUN_PC7_BITS;
  MC_ME.LP_PC[0].= SPC5_ME_LP_PC0_BITS;
  MC_ME.LP_PC[1].= SPC5_ME_LP_PC1_BITS;
  MC_ME.LP_PC[2].= SPC5_ME_LP_PC2_BITS;
  MC_ME.LP_PC[3].= SPC5_ME_LP_PC3_BITS;
  MC_ME.LP_PC[4].= SPC5_ME_LP_PC4_BITS;
  MC_ME.LP_PC[5].= SPC5_ME_LP_PC5_BITS;
  MC_ME.LP_PC[6].= SPC5_ME_LP_PC6_BITS;
  MC_ME.LP_PC[7].= SPC5_ME_LP_PC7_BITS;
  /* Switches again to DRUN mode (current mode) in order to update the
     settings.*/
