16 bit result from ADC
Question asked by songin.sebastian on Jan 7, 2012
Latest reply on Jan 13, 2012 by baird.hal.001
Hello, i test program below. Why i have 16 bit results ?? When i have in another program 10b resolution i have 10b result.
Thank you in advance for reply.
  * @file    ADC/DualADC_RegulSimu_DMAmode1/main.c
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    30-September-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
#include "stm32f4xx.h"
/** @addtogroup STM32F4xx_StdPeriph_Examples
/** @addtogroup ADC_DualADC_RegulSimu_DMAmode1
#define ADC_CCR_ADDRESS    ((uint32_t)0x40012308)
__IO uint16_t ADCDualConvertedValue[4];
void DMA_Config(void);
void GPIO_Config(void);
void ADC1_CH10_CH11_Config(void);
void ADC2_CH11_CH12_Config(void);
  * @param  None
  * @retval None
int main(void)
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f4xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f4xx.c file
  /* Enable peripheral clocks *************************************************/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1|RCC_APB2Periph_ADC2, ENABLE);
  /* DMA2 Stream0 channel0 configuration **************************************/
  DMA_Config();
  /* ADCs configuration ------------------------------------------------------*/
  /* Configure ADC Channel10, 11, 12 pin as analog input */
  GPIO_Config();
  /* ADC Common Init */
  ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_RegSimult;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  /* ADC1 regular channels 10, 11 configuration */
  ADC1_CH10_CH11_Config();
  /* ADC2 regular channels 11, 12 configuration */
  ADC2_CH11_CH12_Config();
  /* Enable DMA request after last transfer (Multi-ADC mode)  */
  ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC2 */
  ADC_Cmd(ADC2, ENABLE);
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConv(ADC1);
  while (1)
  * @brief  ADC1 regular channels 10 and 11 configuration
  * @param  None
  * @retval None
  ADC_InitTypeDef ADC_InitStructure;
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_NbrOfConversion = 2;
  ADC_Init(ADC1, &ADC_InitStructure);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_3Cycles);
  * @brief  ADC2 regular channels 11, 12 configuration
  * @param  None
  * @retval None
  ADC_Init(ADC2, &ADC_InitStructure);
  ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
  ADC_RegularChannelConfig(ADC2, ADC_Channel_12, 2, ADC_SampleTime_3Cycles);
  * @brief  DMA Configuration
  * @param  None
  * @retval None
  DMA_InitTypeDef DMA_InitStructure;
  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCDualConvertedValue;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC_CCR_ADDRESS;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 4;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  /* DMA2_Stream0 enable */
  DMA_Cmd(DMA2_Stream0, ENABLE);
  * @brief Configure ADC Channels 10, 11, 12 pins as analog inputs
  * @param  None
  * @retval None
  /* ADC Channel 10 -> PC0
     ADC Channel 11 -> PC1
     ADC Channel 12 -> PC2
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
