STM32Cube RTC Clock issues
Question asked by vigelette.george on Aug 29, 2014
Latest reply on Aug 29, 2014 by vigelette.george
Hi Everyone, hopefully someone can shed some light on my issue that I keep seeing.  I set the RTC clock from the cellular chipset and get the time every minute with the following results.
Global Date: Aug 29, 2014  Time: 08:49 AM
Updated Time: 08:49 AM
Updated Time: 08:50 AM
Updated Time: 08:51 AM
Updated Time: 08:52 AM
Updated Time: 08:53 AM
Updated Time: 08:54 AM
Updated Time: 08:55 AM
Updated Time: 08:56 AM
Updated Time: 08:57 AM
Updated Time: 08:64 AM
DATA: AT+CCLK?
DATA: +CCLK: "14/08/29,09:27:16-16"
Setting RTC Clock
Updated Time: 09:28 AM
Updated Time: 09:29 AM
Updated Time: 09:30 AM
Updated Time: 09:31 AM
Updated Time: 09:16 AM
Updated Time: 09:17 AM
Updated Time: 09:18 AM
Updated Time: 09:19 AM
Updated Time: 09:20 AM
Updated Time: 09:21 AM
As you can see for the first few minutes the clock updates as expected and then starts to have issues.
I am using STM32Cube with FreeRTOS on a STM32F415VG processor using HSE and LSI for the clock settings.  The following are the functions used to configure, set the time, and update my time string.
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
  __PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.LSIState = RCC_LSI_ON;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1
                              |RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
  PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
/* RTC init function */
void MX_RTC_Init(void)
  /**Initialize RTC and set the Time and Date
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_12;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  HAL_RTC_Init(&hrtc);
void HAL_RTC_MspInit(RTC_HandleTypeDef* hrtc)
     __HAL_RCC_RTC_ENABLE();
int8_t rtc_SetDateTime(char* dateTimeStr)
  RTC_TimeTypeDef sTime;
  RTC_DateTypeDef sDate;
     uint8_t month;
     uint8_t date;
     uint8_t year;
     uint8_t hour;
     uint8_t minute;
     uint8_t second;
     uint8_t ssecond;
     char* pData = NULL;
     // parse string
     pData = strstr(dateTimeStr, "\"");
     if(pData != NULL)
          pData++;
          //sscanf(dateTimeStr, "%hhu/%hhu/%hhu %hhu:%hhu:%hhu", &sDate.Month, &sDate.Date, &sDate.Year, &sTime.Hours, &sTime.Minutes , &sTime.Seconds);
          sscanf(pData, "%hhu/%hhu/%hhu,%hhu:%hhu:%hhu-%hhu", &year, &month, &date, &hour, &minute, &second, &ssecond);
          if(hour>12)
               sTime.Hours = hour-12;
               sTime.TimeFormat = RTC_HOURFORMAT12_PM;
          else
               sTime.Hours = hour;
               sTime.TimeFormat = RTC_HOURFORMAT12_AM;
          sTime.Minutes = minute;
          sTime.Seconds = second;
          sTime.SubSeconds = ssecond;
          sDate.Month = month;
          sDate.Date = date;
          sDate.Year = year;
          sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
          sTime.StoreOperation = RTC_STOREOPERATION_RESET;
          sDate.WeekDay = RTC_WEEKDAY_FRIDAY;
          if(HAL_RTC_SetDate(&hrtc,&sDate,FORMAT_BCD) != HAL_OK)
               printf("Error setting the Date\n\r");
          if(HAL_RTC_SetTime(&hrtc,&sTime,FORMAT_BCD) != HAL_OK)
               printf("Error setting the Time\n\r");
          return 1;
          return 0;
int8_t rtc_UpdateTime(void)
     memset(g_timeStr,0,9);
     HAL_RTC_GetTime(&hrtc, &sTime, FORMAT_BCD);
     sprintf(g_timeStr, "%02hhu:%02hhu %s", sTime.Hours, sTime.Minutes, sTime.TimeFormat==0x00?"AM":"PM");
     printf("Updated Time: %s\n\r", g_timeStr);
     return 1;
Any help would be greatly appreciated, and thank you in advance.
George
