export Antenna design to vector file
Question asked by yair on Feb 19, 2017
first off, thank you for the online tool and the AN2866 whitepaper which is the clearest piece i read about the subject of nfc antenna design.
my issue with the online tool is the output is only in the form of a flash object.
to use it with my paper based nfc antennas i need to screen capture and do a bitmap tracing. it could be easier to export to an image or even better , to a vector format like SVG.
but if thats not in the scope a quick solution is to have an option to remove the nice rendering of the antenna and replace with 2 color b/w impression. currently the drop shadows hurt my conversion.
thanks again
