Problem with External Interrupt
Question asked by ramesh.raja on Aug 23, 2014
Latest reply on Aug 25, 2014 by ramesh.raja
Hello Sir,
I'm facing the problem with external interrupt while using debugger. I'm using PC14 as external input key and PA15 as normal input key. So,when I was using debugger if I pressed the normal key(PA15) it is activating the external interrupt which is connected to PC14. If I remove the debugger it's working fine. Please Tell me the solution.
