STM32 Embedded Matlab target complaining about "quote mismatch" when building Simulink model
Question asked by Sebastian K. on Feb 6, 2017
Latest reply on Feb 9, 2017 by Sebastian K.
I am having a problem getting the STM32 Embebbed Matlab/Simulink Target to run. I am following the example in the STM32_MAT-TARGET_HandsOn.pdf document for the third example (everything on STM32) step by step, but whenever I try to build the model from Simulink I get the error:
=== Build (Elapsed: 0.840 sec) ===
    ### Real-Time Workshop build procedure for method: 'entry
    ### modelName: 'Test3
    ### gcs: 'Test3
    ### bdroot: 'Test3
    ### Starting Real-Time Workshop build procedure for model: Test3
    ### Windows version:win64
    ### Model connectivity is: normal
    ### Create verification block: None
    ### Real-Time Workshop build procedure for method: 'error
    ### gcs: 'Test3
    ### bdroot: 'Test3
    ### Real-Time Workshop build procedure for model: 'Test3' aborted due to an error.
    Error: Syntax error while setting code generation options string: quote mismatch
and no code is generated. I have played around with most of the STM-specific options, but it makes no difference. I am using Matlab R2015b, Win7, Nucleo-F767ZI board and Matlab Target v4.4.1.
Did anyone else encounter that error, or has an idea what could cause it?
