STM32F437 DMA FEIF0 error
Question asked by John Hite on Feb 2, 2017
Latest reply on Feb 2, 2017 by Clive One
I have the following DMA/UART setups on my processor. I print a login prompt. The first two characters get echoed OK but then I get an FEIF0 error. Also the documents talk about 'beats'. What are beats?
Thanks,
jh
//TX setup
DMA_InitTypeDef uart_dma;
if (chars_in_buffer > 0)
    DMA_DeInit(DMA1_Stream0);
    DMA_StructInit(&uart_dma);
    uart_dma.DMA_Channel = DMA_Channel_5;
    uart_dma.DMA_DIR = DMA_DIR_MemoryToPeripheral;
    uart_dma.DMA_Memory0BaseAddr = (uint32_t)&dma_tx_block[0];
    uart_dma.DMA_BufferSize = (uint32_t)chars_in_buffer;
    uart_dma.DMA_PeripheralBaseAddr = (uint32_t)&DebugUart->DR;
    uart_dma.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    uart_dma.DMA_MemoryInc = DMA_MemoryInc_Enable;
    uart_dma.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    uart_dma.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    uart_dma.DMA_Mode = DMA_Mode_Normal;//XX
    uart_dma.DMA_Priority = DMA_Priority_High;
    uart_dma.DMA_FIFOMode = DMA_FIFOMode_Enable;//XX
    uart_dma.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;//XX
    uart_dma.DMA_MemoryBurst = DMA_MemoryBurst_INC4;
    uart_dma.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_Init(DMA1_Stream0, &uart_dma);
    USART_DMACmd(UART8, USART_DMAReq_Tx, ENABLE);
    DMA_Cmd(DMA1_Stream0, ENABLE);
    DMA_ClearITPendingBit(DMA1_Stream0, DMA_IT_TCIF0);
    DMA_ITConfig(DMA1_Stream0, DMA_IT_TC, ENABLE);
    FLAG_SET(portminder_flags, PFLAG_TX_BUSY);
//RX setup
static void RestartDMA(void)
    DMA_DeInit(DMA1_Stream6);
    uart_dma.DMA_DIR = DMA_DIR_PeripheralToMemory;
    uart_dma.DMA_Memory0BaseAddr = (uint32_t)&dma_rx_block[0];
    uart_dma.DMA_BufferSize = PORTMINDER_BLOCK_SZ;
    uart_dma.DMA_Mode = DMA_Mode_Circular;
    uart_dma.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    //DMA_FlowControllerConfig(DMA1_Stream6, 0);
    DMA_Init(DMA1_Stream6, &uart_dma);
    USART_DMACmd(UART8, USART_DMAReq_Rx, ENABLE);
    DMA_Cmd(DMA1_Stream6, ENABLE);
    DMA_ClearITPendingBit(DMA1_Stream6, DMA_IT_TCIF6);///????
    DMA_ITConfig(DMA1_Stream6, DMA_IT_TC, ENABLE);
void DMARxISR(void)
    CPU_SR_ALLOC();
    CPU_INT_DIS();
    OSIntNestingCtr++;
    CPU_INT_EN();
    if (DMA_GetITStatus(DMA1_Stream6, DMA_IT_TCIF6) == SET) {
        //DMA_Cmd(DMA1_Stream6, DISABLE);
    OSIntExit();
void DMATxISR(void)
    CPU_SR_ALLOC();
    CPU_INT_DIS();
    OSIntNestingCtr++;
    CPU_INT_EN();
    if (DMA_GetITStatus(DMA1_Stream0, DMA_IT_TCIF0) == SET) {
        DMA_Cmd(DMA1_Stream0, DISABLE);
    OSIntExit();
