Duplicated code in stm32l0xx_hal_pcd.c V1.8.0
Question asked by atanasov.daniel on Jan 22, 2017
Latest reply on Mar 16, 2018 by Darius B
I just started a mini project using USB CDC with STM32CubeMX and while trying to figure out how to use CDC driver i found this piece of code.
I think there is code duplication (copy-paste) in STM32Cube_FW_L0_V1.8.0/Drivers/STM32L0xx_HAL_Driver/Src/stm32l0xx_hal_pcd.c
In function PCD_EP_ISR_Handler(),
In section /* Decode and service non control endpoints interrupt  */ for Correct Transfer for transmission,
from /* IN double Buffering*/ to /*multi-packet on the NON control OUT endpoint*/.
Code in above described section wrongly writes data to PMA memory.
The later call to HAL_PCD_EP_Transmit() writes right data to PMA memory and sends it.
Possible side effect with duplicated code in PCD_EP_ISR_Handler() can be a calling of function PCD_FreeUserBuffer() twice in case of ep->doublebuffer != 0U.
