fresh Custom HID Project, not flashable on my STM32F4
Question asked by lampe.julian on Jan 21, 2017
Latest reply on Feb 26, 2017 by lampe.julian
Hey guys,
I created 2 sets of projects with CubeMX for my STM32F429I-Disc 1 board.
I project is a Device HID project, the other one is a Device Custom HID project.
The Device HID projects works fine, the Custom HID project compiles correctly but will not flash onto my MCU.
I'm aware that for the custom HID USB routine to actually work, i'll have to adjust the USB descriptors. I have not done this yet!
However this problem looks like more severe problem to me. Is there something wrong with the cube MX code generation?
The log of the failed Custom HID looks like this
Open On-Chip Debugger 0.10.0-dev-00267-g884c33c (2016-03-16-12:22)
Licensed under GNU GPL v2
For bug reports, read
    http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
srst_only separate srst_nogate srst_open_drain connect_assert_srst
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v25 API v2 SWIM v14 VID 0x0483 PID 0x374B
Info : using stlink api v2
Info : Target voltage: 2.867916
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
adapter speed: 1800 kHz
stm32f4x.cpu: target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08000250 msp: 0x20030000
configuring PLL
** Programming Started **
auto erase enabled
Error: Invalid command argument
image.base_address option value ('Test.elf') is not valid
** Programming Failed **
shutdown command invoked
and this  is the log of the working HID Device
configuring PLL
auto erase enabled
Info : device id = 0x20016419
Info : flash size = 2048kbytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x20000046 msp: 0x20030000
wrote 262144 bytes from file Debug/Giessomat.elf in 7.384422s (34.668 KiB/s)
** Programming Finished **
** Verify Started **
xPSR: 0x61000000 pc: 0x2000002e msp: 0x20030000
verified 213980 bytes in 1.634094s (127.878 KiB/s)
** Verified OK **
** Resetting Target **
do you have any idea how to solve the problem?
greets Julian
