STM32F3xx Clock configuration
Question asked by Laga.Freya on Jan 18, 2017
Latest reply on Jan 28, 2017 by Laga.Freya
Hi to all,
this is my first project using a STM32F373 MCU, but I am not able even to let a LED blink.
I assume that system clock is not running as I get no response also enabling the MCO and check it with a scope.
For my clock initialization routine I used the cubemx code as base. Here is my code:
/*-------------------------------- HSE - HSI Configuration -----------------------*/
    if(!HSEHSI)
        if(!(RCC->CR & RCC_CR_HSION))    RCC->CR |= RCC_CR_HSION;    // If HSI in not ON, just enable it
        while(!(RCC->CR & RCC_CR_HSIRDY));
        RCC->CR &= ~RCC_CR_PLLON;    // Disable PLL
        RCC->CFGR &= ~RCC_CFGR_PLLSRC_HSE_PREDIV;    // HSI as PLL source
    else
        RCC->CR &= ~RCC_CR_HSEBYP;        // Disable HSE_BYPASS
        RCC->CR |= RCC_CR_HSEON;            // Enable HSE
        while(!(RCC->CR & RCC_CR_HSERDY));    // Wait for HSE being ready
        while(RCC->CR & RCC_CR_PLLRDY);    // Wait for PLL disabled
        RCC->CFGR |= RCC_CFGR_PLLSRC_HSE_PREDIV;    // HSE as PLL source
        RCC->CFGR  &= ~RCC_CFGR_PLLXTPRE;    // HSE not divided
        RCC->CFGR2 &= (RCC->CFGR2 & ~RCC_CFGR2_PREDIV) | RCC_CFGR2_PREDIV_DIV1;    // Input clock not divided
    RCC->CFGR = ((RCC->CFGR & ~RCC_CFGR_PLLMUL) | RCC_CFGR_PLLMUL9);    // PLL = 9*HSE
    RCC->CFGR = (RCC->CFGR & ~RCC_CFGR_SW) | RCC_CFGR_SW_PLL;    // PLL as SYSTEM CLOCK
    RCC->CFGR = (RCC->CFGR & ~RCC_CFGR_PLLXTPRE) | RCC_CFGR_PLLXTPRE_HSE_PREDIV_DIV1;    // HSE/PREDIV clock not divided for PLL entry
    RCC->CFGR |= RCC_CFGR_USBPRE_DIV1_5;    // USB divided by 3
    RCC->CFGR = (RCC->CFGR & ~RCC_CFGR_PPRE2) | RCC_CFGR_PPRE2_DIV1;    // APB2 not divided
    RCC->CFGR = (RCC->CFGR & ~RCC_CFGR_PPRE1) | RCC_CFGR_PPRE1_DIV2;    // APB1 divided by 2
    RCC->CFGR = (RCC->CFGR & ~RCC_CFGR_HPRE) | RCC_CFGR_HPRE_DIV1;    // AHB not divided
    RCC->CFGR2 &= (RCC->CFGR & ~RCC_CFGR_MCO) | RCC_CFGR_MCO_SYSCLK;    // Enable MCO
    RCC->CR |= RCC_CR_PLLON;    // Enable PLL
    while(!(RCC->CR & RCC_CR_PLLRDY));    // Wait for PLL enabled
//    FLASH->ACR = (FLASH->ACR &(~FLASH_ACR_LATENCY)) | FLASH_ACR_LATENCY_2;    // Set FLASH latency = 2
    /*-------------------------------- LSE - LSI Configuration -----------------------*/
    if(!LSELSI)
        if(!(RCC->CSR & RCC_CSR_LSION)) RCC->CSR |= RCC_CSR_LSION;    //Enable LSI
        while(!(RCC->CSR & RCC_CSR_LSIRDY));    // Wait for LSI ready
        RCC->BDCR = (RCC->BDCR & ~RCC_BDCR_RTCSEL) | RCC_BDCR_RTCSEL_LSI;    // LSI as RTC clock
    else
        PWR->CR  |= PWR_CR_DBP;    // Disable RTC write protect
        if(!(RCC->BDCR & RCC_BDCR_LSEON))    RCC->BDCR = (RCC->BDCR & ~RCC_BDCR_LSE) | RCC_BDCR_LSEON;    // If LSE in not ON, just enable it
        while(!(RCC->BDCR & RCC_BDCR_LSERDY));
        RCC->BDCR = (RCC->BDCR & ~RCC_BDCR_RTCSEL) | RCC_BDCR_RTCSEL_LSE;    // LSE as RTC clock
    RCC->CIR = 0x00000000;                // Disable all interrupts
Someone encountered this problem already?
Do I make some mistakes?
Thank you
Freya
