Corrected clock setting from cubemx ?
Question asked by Md Mubdiul Hasan on Dec 16, 2016
Latest reply on Dec 29, 2016 by Md Mubdiul Hasan
Hello Everyone,
I look forward to whom who knows Cubemx well in this community,
In my generated cubemx, for GPIO initialization the code says,
static void MX_GPIO_Init(void)
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
But the error sign of Eclipse says following
wrong_clock
At this consideration the clock configuration at cubemx ,
cnf
During this time my RCC setting was,
rcc
Take a look here, if you feel any mismatch ,
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit;
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSI;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
1. Explain things which should be necessary here,
2. If RCC is ON then what should be the effect?
3. RCC is necessary for every design of STM32F07xxx?
Hasan
