STM32F7 HAL 1.1.0 ADC Migration Problem
Question asked by Keaven on Dec 6, 2016
Latest reply on Mar 26, 2018 by Max Rest
we have a project using all the three ADCs of the F7.  It runs without any problem on Keil package 2.5.0 which includes HAL 1.0.4.  Now, I want to upgrade to version STM32F7 HAL 1.1.0 but I am having problem with ADC3 dma acquisition.
The value isn't good anymore because I am getting this error HAL_DMA_ERROR_NO_XFER.
What I need to change to get it work?
Here is my initialization code
void InitADCs (void)
    ADC_ChannelConfTypeDef ChannelConfig;
    //ADC3
    hADC3.Instance                      = ADC3;
    hADC3.Init.ClockPrescaler           = ADC_CLOCKPRESCALER_PCLK_DIV2;
    hADC3.Init.Resolution               = ADC_RESOLUTION12b;
    hADC3.Init.ScanConvMode             = ENABLE;
    hADC3.Init.ContinuousConvMode       = DISABLE;
    hADC3.Init.DiscontinuousConvMode    = DISABLE;
    hADC3.Init.NbrOfDiscConversion      = 0;
    hADC3.Init.ExternalTrigConvEdge     = ADC_EXTERNALTRIGCONVEDGE_NONE;
    hADC3.Init.ExternalTrigConv         = ADC_SOFTWARE_START;
    hADC3.Init.DataAlign                = ADC_DATAALIGN_RIGHT;
    hADC3.Init.NbrOfConversion          = 6;
    hADC3.Init.DMAContinuousRequests    = ENABLE;
    hADC3.Init.EOCSelection             = DISABLE;
    HAL_ADC_Init(&hADC3);
    //Vpeak
    ChannelConfig.Channel       = ADC_CHANNEL_4;
    ChannelConfig.Rank          = 1;
    ChannelConfig.SamplingTime  = ADC_SAMPLETIME_3CYCLES;
    ChannelConfig.Offset        = 0;
    HAL_ADC_ConfigChannel(&hADC3, &ChannelConfig);
    //Vdark
    ChannelConfig.Channel       = ADC_CHANNEL_5;
    ChannelConfig.Rank          = 2;
    //ILamp
    ChannelConfig.Channel       = ADC_CHANNEL_6;
    ChannelConfig.Rank          = 3;
    //Vmano
    ChannelConfig.Channel       = ADC_CHANNEL_7;
    ChannelConfig.Rank          = 4;
    //Vsupply
    ChannelConfig.Channel       = ADC_CHANNEL_8;
    ChannelConfig.Rank          = 5;
    //Temp
    ChannelConfig.Channel       = ADC_CHANNEL_15;
    ChannelConfig.Rank          = 6;
    return;
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
    GPIO_InitTypeDef  GPIO_InitStructure;
    //Diagnostics
    if(hadc->Instance == ADC3)
        //##-1- Enable peripherals and GPIO Clocks #################################
        __GPIOF_CLK_ENABLE();
        __ADC3_CLK_ENABLE();
        //##-2- Configure peripheral GPIO ##########################################
        //Configure PF6 as analog input for Vpeak Channel4
        GPIO_InitStructure.Pin      = GPIO_PIN_6;
        GPIO_InitStructure.Mode     = GPIO_MODE_ANALOG;
        GPIO_InitStructure.Speed    = GPIO_SPEED_LOW;
        GPIO_InitStructure.Pull     = GPIO_NOPULL ;
        //GPIO_InitStructure.Alternate = GPIO_AF0_RTC_50Hz; //DONT CARE
        HAL_GPIO_Init(GPIOF, &GPIO_InitStructure);
        //Configure PF7 as analog input for Vdark Channel5
        GPIO_InitStructure.Pin      = GPIO_PIN_7;
        //Configure PF8 as analog input for ILamp Channel6
        GPIO_InitStructure.Pin      = GPIO_PIN_8;
        //Configure PF9 as analog input for Vmano Channel7
        GPIO_InitStructure.Pin      = GPIO_PIN_9;
        //Configure PF10 as analog input for Vsupply Channel8
        GPIO_InitStructure.Pin      = GPIO_PIN_10;
        //Configure PF5 as analog input for Temp Channel15
        GPIO_InitStructure.Pin      = GPIO_PIN_5;
        //##-3- Configure the DMA streams ##########################################
        //DMA2 Stream 0 Channel 0 ADC1 fixed length transfer of 2140
        hDMA2_ADC3.Instance                  = DMA2_Stream1;
        hDMA2_ADC3.Init.Channel              = DMA_CHANNEL_2;
        hDMA2_ADC3.Init.Direction            = DMA_PERIPH_TO_MEMORY;
        hDMA2_ADC3.Init.PeriphInc            = DMA_PINC_DISABLE;
        hDMA2_ADC3.Init.MemInc               = DMA_MINC_ENABLE;
        hDMA2_ADC3.Init.PeriphDataAlignment  = DMA_PDATAALIGN_HALFWORD;
        hDMA2_ADC3.Init.MemDataAlignment     = DMA_MDATAALIGN_HALFWORD;
        hDMA2_ADC3.Init.Mode                 = DMA_NORMAL;
        hDMA2_ADC3.Init.Priority             = DMA_PRIORITY_HIGH;
        hDMA2_ADC3.Init.FIFOMode             = DMA_FIFOMODE_DISABLE;
        hDMA2_ADC3.Init.FIFOThreshold        = DMA_FIFO_THRESHOLD_1QUARTERFULL;
        hDMA2_ADC3.Init.MemBurst             = DMA_MBURST_SINGLE;
        hDMA2_ADC3.Init.PeriphBurst          = DMA_PBURST_SINGLE;
        HAL_DMA_Init(&hDMA2_ADC3);
        // Associate the initialized DMA handle to the the ADC handle
        __HAL_LINKDMA(hadc, DMA_Handle, hDMA2_ADC3);
        //##-4- Configure the NVIC for DMA #########################################
        HAL_NVIC_SetPriority(DMA2_Stream1_IRQn, 0x0F, 0x0F);
        HAL_NVIC_EnableIRQ(DMA2_Stream1_IRQn);
Thank you!
