stm32f0 disco usart1 rx using interrupt
Question asked by Nimit Vachhani on Dec 6, 2016
Latest reply on Feb 8, 2017 by Mark Shoe
Greetings People,
I am new to STM32. I have stm32f0 discovery board with stm32f051r8 mcu on it. I am trying to develop usart tx and rx program using mdk arm. I have configured project in stm32 cube and i use A9 and A10 pins for tx and rx.
The problem - When i send "Hello \r" from my pc to stm32f0 discovery it receives "H" and when i look into debug window rxState is "HAL_UART_STATE_BUSY_RX" and ISR is "0x00000000".
Below is main.c
#include "stm32f0xx_hal.h"
#include "main.h"
#include <stdio.h>
#include <string.h>
unsigned char cr = 0x0D;
unsigned char tx_data = 0x00;
unsigned char tx_indx = 0x00;
unsigned char rx_data = 0x00;
unsigned char rx_indx = 0x00;
unsigned char rx_buff[32];
char buff[32]="";
UART_HandleTypeDef huart1;
void Error_Handler(void);
static void MX_USART1_UART_Init(void);
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_USART1_UART_Init();
     HAL_UART_Receive_IT(&huart1, &rx_data, 1);     //activate UART receive interrupt every time
  while (1)
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
  RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
    Error_Handler();
                              |RCC_CLOCKTYPE_PCLK1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
    Error_Handler();
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    Error_Handler();
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
     if (HAL_UART_DeInit(&huart1) != HAL_OK)
    Error_Handler();
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  /*Configure GPIO pin : btn_Pin */
  GPIO_InitStruct.Pin = btn_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  HAL_GPIO_Init(btn_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : LD4_Pin LD3_Pin */
  GPIO_InitStruct.Pin = LD4_Pin|LD3_Pin;
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOC, LD4_Pin|LD3_Pin, GPIO_PIN_RESET);
  while(1)
#ifdef USE_FULL_ASSERT
#endif
below is my stm32f0xx_it.c
  * @file    stm32f0xx_it.c
  * @brief   Interrupt Service Routines.
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f0xx.h"
#include "stm32f0xx_it.h"
#include "main.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
/* External variables --------------------------------------------------------*/
extern UART_HandleTypeDef huart1;
/*            Cortex-M0 Processor Interruption and Exception Handlers         */
* @brief This function handles System tick timer.
void SysTick_Handler(void)
  /* USER CODE BEGIN SysTick_IRQn 0 */
  /* USER CODE END SysTick_IRQn 0 */
  HAL_IncTick();
  HAL_SYSTICK_IRQHandler();
  /* USER CODE BEGIN SysTick_IRQn 1 */
  /* USER CODE END SysTick_IRQn 1 */
/* STM32F0xx Peripheral Interrupt Handlers                                    */
/* Add here the Interrupt Handlers for the used peripherals.                  */
/* For the available peripheral interrupt handler names,                      */
/* please refer to the startup file (startup_stm32f0xx.s).                    */
* @brief This function handles USART1 global interrupt / USART1 wake-up interrupt through EXTI line 25.
void USART1_IRQHandler(void)
HAL_UART_IRQHandler(&huart1);
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
     if (huart->Instance == USART1)     //current UART
               if(rx_indx == 0){for (int i=0;i<100;i++) rx_buff[i]=0;}
               if(rx_data != cr)
                    rx_buff[rx_indx] = rx_data;
               else if(rx_data == cr)
                    tx_indx = 0x00;
                    tx_data = rx_buff[tx_indx];
        HAL_UART_Transmit_IT(huart, &tx_data, 1);
               rx_indx ++;
               if(rx_indx > 0x1F)
                    rx_indx = 0;
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart)
          tx_indx ++;
          if(tx_indx < rx_indx)
      HAL_UART_Transmit_IT(huart, &tx_data, 1)     ;
          else
               rx_indx = 0;
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
