ERROR: Unable to load CA certificate
Question asked by Zirconium on Jul 17, 2016
Latest reply on Jul 21, 2016 by Zirconium
Doing the Example 1 of the AN4683 (TLS Example 1, mutual auth), all commands work without problem (keys and certificate generation), same for imports in Wifi module (send back "OK")
But the last command : AT+S.SOCKON=ipaddress,443,s returns "ERROR: Unable to load CA certificate" (of course ipaddress is the ip address of my TLS server)
I have several questions :
- Is the CA certificate checked during import in the module ? According to my test, the certificate is not checked during import (could you confirm ?)
- Is the example given in the doc works for you ?
- Any clue ?
Thanks a lot
Zirco
