TIM1 Complementary Signals
Question asked by padilla.aaron on Jan 17, 2014
Latest reply on Jun 7, 2014 by prado.maycon
Hi, I would like to know if someone had been capable to use  the complementary outputs of timer 1, I found  an example in the standard peripheral library called
TIM1_ComplementarySignals_DeadTime_Break_Lock
I flashed it in the Discovery board, the normal OC outputs are OK but the complementary outputs doesn't work y have changed polarity and read the datasheet but I can't get it to work,
Could you advise?
Tnx
