st6 eprom programmer
Question asked by saeedi.mahdiyeh on Apr 28, 2011
hello every body,
I have a problem using st6 eprom programmer with WINEE software,
I use WINEE software to program st62T03C so I connect the board to PC using serial port and set all the project configuration which are required in WINEE but the problem is that when we want to blank check the eprom we got this message "! EPROM area not blank", we got this message even if there isn't any micro in the board, the jumper is set in remote mode.
previously I programed this micro with the same code using st6 starter kit and everything was ok, but now I dont know what the problem is.
thanks in advance
