BLueNRG: No Advertizing
Question asked by robitzki.torsten on May 12, 2015
Latest reply on Oct 1, 2015 by Marchese.Graziella
I want to use a BlueNRG as HCI device. I’ve used the ACI Command Write_Config_Data to set a public address (0xaa, 0x00, 0x00, 0xE1, 0x80, 0x02). I use the HCI command „LE Set Advertising Data Command“ and finally use the HCI command „LE Set Advertise Enable Command“.
All that commands report successfully execution but when using a generic BLE Client (like BLExplr on iOS), I can not see any advertising Device. What am I’m missing? I don’t want to use the GATT/ATT stack of the BlueNRG, because I want to use BlueNRG to test my own GATT stack.
Thank you for every tipp or comment on this.
Cheers,
Torsten
