DAC control register
Question asked by none.ezechkiel on Mar 11, 2011
Latest reply on Mar 21, 2011 by none.ezechkiel
hi,
i use a STM 32 discovery , and i would like to use the DAC without the library.
i make my driver , a pointer initialised on the address 0x4000 7400, and a function for write the value 0x0003 0003 in the control register.
But when i debug step by step my Control register keeps to 0, and when i write in the window control same problem my control register keeps to 0.
I link my program.
this is my main function:
#include "DAC_struct_h.h"
#include "CDSE_struct.h"
int main(void)
ptr_DAC_perso = (volatile struct DAC_perso *) 0x40007400;
CDSE_DAC_init();
unsigned int Dac_out_perso1_init,Dac_out_pe rso2_init,Dac_out_perso1,Dac_o  ut_perso2,DAC_test_init;
DAC_test_init           = ptr_DAC_perso -> CDSE_CTRL_REG.Global ;
Dac_out_perso1_init= ptr_DAC_perso -> CDSE_DAC_DOR1.Global ;
Dac_out_perso2_init= ptr_DAC_perso -> CDSE_DAC_DOR2.Global ;
while (1)
ptr_DAC_perso -> CDSE_DAC_DHR12R1.Global = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR12L1.Global = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR8R1.Global  = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR12R2.Global = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR12L2.Global = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR8R2.Global  = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR12RD.Global = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR12LD.Global = 0xFFFFFFFF ;
ptr_DAC_perso -> CDSE_DAC_DHR8RD.Global  = 0xFFFFFFFF ;
Dac_out_perso1= ptr_DAC_perso -> CDSE_DAC_DOR1.Global ;
Dac_out_perso2= ptr_DAC_perso -> CDSE_DAC_DOR2.Global ;
this is my driver:
#ifndef DAC_struct_h_
#define DAC_struct_h_
struct CTRL_REG_bitfield_acces
unsigned int EN1           :1;
unsigned int BOFF1           :1;
unsigned int TEN1           :1;
unsigned int TSEL1          :3;
unsigned int WAVE1          :2;
unsigned int MAMP1          :4;
unsigned int DMA_EN1      :1;
unsigned int DMAU_DRIE1     :1;
unsigned int reserve1     :2;
unsigned int EN2           :1;
unsigned int BOFF2           :1;
unsigned int TEN2           :1;
unsigned int TSEL2          :3;
unsigned int WAVE2          :2;
unsigned int MAMP2          :4;
unsigned int DMA_EN2      :1;
unsigned int DMAU_DRIE2     :1;
unsigned int reserve2     :2;
union CTRL_REG_acces
struct CTRL_REG_bitfield_acces CTRL_REG_bitfield;
unsigned int Global;
struct DAC_perso
union CTRL_REG_acces             CDSE_CTRL_REG;
union DAC_SWTRIGR_access       CDSE_DAC_SWTRIGR;
union DAC_DHR12R1_access       CDSE_DAC_DHR12R1;
union DAC_DHR12L1_access       CDSE_DAC_DHR12L1;
union DAC_DHR8R1_access            CDSE_DAC_DHR8R1;
union DAC_DHR12R1_access       CDSE_DAC_DHR12R2;
union DAC_DHR12L1_access       CDSE_DAC_DHR12L2;
union DAC_DHR8R1_access            CDSE_DAC_DHR8R2;
union DAC_DHR12RD_access       CDSE_DAC_DHR12RD;
union DAC_DHR12LD_access       CDSE_DAC_DHR12LD;
union DAC_DHR8RD_access            CDSE_DAC_DHR8RD;
union DAC_DOR1_access            CDSE_DAC_DOR1;
union DAC_DOR2_access            CDSE_DAC_DOR2;
union DAC_SR_access                 CDSE_DAC_SR;
volatile struct DAC_perso *ptr_DAC_perso;
#endif
and my function write :
void CDSE_DAC_init(void)
ptr_DAC_perso -> CDSE_CTRL_REG.Global = 0x00030003 ;
if you have a solution for my problem , i would sincerely happy.
Thank a lot
