STM32F4 LwIP memp Pbuf Linked List Pointer Corruption Causes Hard Fault
Question asked by Donovan.Nathan on Nov 16, 2016
Latest reply on Nov 17, 2016 by waclawek.jan
Hello STM32 group.  I don't post a lot, but frequently read and benefit from the conversations on this board so I wanted to update you on something we've recently spent quite a bit of time debugging.
We created an application based on the STM32F4x7_ETH_LwIP_V1.1.1 project.  (Apparently if you use the cube utility the default LwIP settings are configured the same way.  I haven't verified this.)
The problem presented with somewhat random hard faults.  If we pinged the controller continuously it might happen 4 or 5 times a day.  These were usually coming from the memp_tab[type] = memp->next; instruction in msg = (struct tcpip_msg *)memp_malloc(MEMP_TCPIP_MSG_INPKT); call from the tcpip_input() function in tcpip.c.  The pointer memp->next was usually pointed out to some random inaccessible place in memory, totally random.  Occasionally the faults came from other places in memory.
The SYS_LIGHTWEIGHT_PROT in lwipopts.h was switched off.  Enabling this switch fixed our problem.  Apparently the buffer allocation or memory allocation function was getting interrupted.  Switching this on protects the allocation/deallocation critical regions.
Hope this helps.
