STM32Cube FATFS Problem in STM32F103
Question asked by keshavarz.abbas on Oct 23, 2016
Latest reply on Oct 24, 2016 by keshavarz.abbas
Hello eveyone,
I have a board containing STM32F103RET and micro SD Card interface.
I have utilized FATFS library and Standard peripheral library to use micro SD card on it successfully using SDIO interface in wide-bus mode.
but with using STM32Cube code generator, unfortunately I can't get any result.
all I did was to extend Stack size to 0x1000 and use this code:
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f1xx_hal.h"
#include "fatfs.h"
#include <stdio.h>
#include <string.h>
/* USER CODE END Includes */
SD_HandleTypeDef hsd;
HAL_SD_CardInfoTypedef SDCardInfo;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
FATFS fs;                 // Work area (file system object) for logical drive
FIL fil;                  // file objects
FRESULT    FAT_result;
char SDPath[4];                     // SD card logical drive path
uint32_t byteswritten;                /* File write counts */
uint32_t bytesread;                   /* File read counts */
uint8_t wtext[] = "This is STM32 working with FatFs"; /* File write buffer */
uint8_t rtext[100];                     /* File read buffers */
char filename[] = "STM32cube.txt";
/* USER CODE END PV */
void Error_Handler(void);
static void MX_SDIO_SD_Init(void);
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
   set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_SDIO_SD_Init();
  MX_FATFS_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
    printf("\r\n ****** FatFs Example ******\r\n\r\n");
    //if(FATFS_LinkDriver(&SD_Driver, SDPath) == 0)
        /*##-1- Register the file system object to the FatFs module ##############*/
        sprintf(SDPath,"0:/");
        FAT_result = f_mount(&fs, SDPath, 0);
        if(FAT_result)
            printf(" mount error : %d \r\n",FAT_result);
            Error_Handler();
        else
            printf(" mount sucess!!! \r\n");
        /*##-2- Create and Open new text file objects with write access ######*/
        FAT_result = f_open(&fil, filename, FA_CREATE_ALWAYS | FA_WRITE);
        if(FAT_result)
                printf(" open file error : %d\r\n",FAT_result);
        else
                printf(" open file sucess!!! \r\n");
        /*##-3- Write data to the text files ###############################*/
        FAT_result = f_write(&fil, wtext, sizeof(wtext), (void *)&byteswritten);
        if(FAT_result)
                printf(" write file error : %d\r\n",FAT_result);
        else
                printf(" write file sucess!!! \r\n");
                printf(" write Data : %s\r\n",wtext);
        /*##-4- Close the open text files ################################*/
        FAT_result = f_close(&fil);
        if(FAT_result)
                printf(" close error : %d\r\n",FAT_result);
        else
                printf(" close sucess!!! \r\n");
        /*##-5- Open the text files object with read access ##############*/
        FAT_result = f_open(&fil, filename, FA_READ);
        if(FAT_result)
        else
        /*##-6- Read data from the text files ##########################*/
        FAT_result = f_read(&fil, rtext, sizeof(rtext), (UINT*)&bytesread);
        if(FAT_result)
                printf(" read error!!! %d\r\n",FAT_result);
        else
                printf(" read sucess!!! \r\n");
                printf(" read Data : %s\r\n",rtext);
        /*##-7- Close the open text files ############################*/
        if(FAT_result)
                printf(" close error!!! %d\r\n",FAT_result);
        else
        /*##-8- Compare read data with the expected data ############*/
        if(bytesread == byteswritten)
                printf(" FatFs is working well!!!\r\n");
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
/* SDIO init function */
  hsd.Instance = SDIO;
  hsd.Init.ClockEdge = SDIO_CLOCK_EDGE_RISING;
  hsd.Init.ClockBypass = SDIO_CLOCK_BYPASS_DISABLE;
  hsd.Init.ClockPowerSave = SDIO_CLOCK_POWER_SAVE_DISABLE;
  hsd.Init.BusWide = SDIO_BUS_WIDE_1B;
  hsd.Init.HardwareFlowControl = SDIO_HARDWARE_FLOW_CONTROL_DISABLE;
  hsd.Init.ClockDiv = 0;
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
/* USER CODE BEGIN 4 */
PUTCHAR_PROTOTYPE
    HAL_UART_Transmit( &huart1, (uint8_t *)&ch, 1, 0xFFFF );
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
while running this code, I get FR_NOT_READY error!
Please give me your notes to solve this problem.
Thanks a lot
