How to properly change I2S clock.
Question asked by garberoglio.leon.001 on Oct 6, 2016
Latest reply on Oct 18, 2016 by ForumSTM32.ForumSTM3
Hi, I'm using a STM32F411 on a product that uses I2S to stream some sound to an audio codec.
I use this function to configure oscillator:
void SystemClock_Config(void)
    RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
    __PWR_CLK_ENABLE();
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
    RCC_OscInitStruct.PLL.PLLM = 6;
    RCC_OscInitStruct.PLL.PLLN = 168;
    RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
    RCC_OscInitStruct.PLL.PLLQ = 7;
    HAL_RCC_OscConfig(&RCC_OscInitStruct);
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
    HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2);
    //22050 Hz original del final_09_DPOAE_05_Apexar
//  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_I2S;
//  PeriphClkInitStruct.PLLI2S.PLLI2SN = 192;
//  PeriphClkInitStruct.PLLI2S.PLLI2SM = 12;
//  PeriphClkInitStruct.PLLI2S.PLLI2SR = 2;
//  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
    //44100Hz
//  PeriphClkInitStruct.PLLI2S.PLLI2SN = 271;
     * Esta configuracion es para tener buen % trabajando a 22KHz
//  PeriphClkInitStruct.PLLI2S.PLLI2SN = 429;
//  PeriphClkInitStruct.PLLI2S.PLLI2SR = 4;
     * Esta configuracion es para tener buen % trabajando a 96KHz
    PeriphClkInitStruct.PLLI2S.PLLI2SN = 344;
As you can see I have 4 diferent blocks on I2S clock. I need to use 2 of them on my firmware.
I need to know how can I change just I2S clock frecuency. Could I write just this:
on any part of my code and it will change I2S clock?
Thank
