I need help about UART Transmit Interrupt.
Question asked by karthy.vain on Sep 29, 2016
Latest reply on Sep 30, 2016 by FTITI.Walid
I have two code
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f4xx_hal.h"
void __Delay(void)
for(int i=0;i<=3000000;i++)
    for(int j=0;j<=10;j++);
UART_HandleTypeDef huart1;
void Error_Handler(void);
static void MX_USART1_UART_Init(void);
int count=0;
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_USART1_UART_Init();
    count=1;
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
  HAL_UART_Transmit_IT(&huart1,(uint8_t*)"My Name Is Nedu1",sizeof("My Name Is Nedu1")-1);
    count=3;
  __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
  while (1)
  count=4;
/** System Clock Configuration
void SystemClock_Config(void)
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLQ = 4;
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
/* USER CODE BEGIN 4 */
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart)
   count=2;
    __Delay();
    __Delay();
    __Delay();
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
and this is second code
void __Delay(void)
int count=0;
int main(void)
  HAL_Init();
  MX_GPIO_Init();
    count=1;
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
  __Delay();
       count=3;
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
    __Delay();
  while (1)
  count=4;
    Error_Handler();
    Error_Handler();
    Error_Handler();
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
   count=2;
    __Delay();
    __Delay();
    __Delay();
  * @param  None
  * @retval None
  while(1)
   * @retval None
#endif
In the first code, count is never = 3. its sequence are 1,2 and 4. never is 3.
but in the second code, I have __Delay(); below HAL_UART_Transmit_IT(&huart1,(uint8_t*)"My Name Is Nedu1",sizeof("My Name Is Nedu1")-1); its sequence are 1,2,3 and 4. What different between two code? I used to Kiel5 to debug.
