SDRAM connections on FMC
Question asked by chris250 on Aug 18, 2016
Latest reply on Aug 18, 2016 by chris250
Hoping for some feedback from ST or others who have tested/used this configuration...
The datasheet for the STM32F745xx (also the 746xx) contains Table 11. This shows the FMC pin definition, and lists the following pins for use with SDNWE:
PC0
PH5
Searching through the datasheet I have found that in Table 10 (Pin and Ball Definition) it lists FMC_SDNWE as an alternate function for PA7. However PA7 is not included in the FMC pin definition table.
My question is: can PA7 be used for the FMC_SDNWE signal? There's either an error in Table 10 or an omission from Table 11.
Thanks.
