stm32 fatfs sdio
Question asked by eb3484 on Aug 18, 2016
Latest reply on Aug 19, 2016 by eb3484
Hi
I am trying to use fatfs with my 8gb microsd card on my own stm32f429 board. I use 1-bit sdio configuration and i use the cubemx fatfs example Project for eval board.
if(FATFS_LinkDriver(&SD_Driver, SDPath) == 0)
    /*##-2- Register the file system object to the FatFs module ##############*/
    if(f_mount(&SDFatFs, (TCHAR const*)SDPath, 0) != FR_OK)
      /* FatFs Initialization Error */
      //Error_Handler();
else
  if(f_mkfs((TCHAR const*)SDPath, 0, 0) != FR_OK)
        /* FatFs Format Error */
        //Error_Handler();
      else
        /*##-4- Create and Open a new text file object with write access #####*/
        if(f_open(&MyFile, "STM32.TXT", FA_CREATE_ALWAYS | FA_WRITE) != FR_OK)
          /* 'STM32.TXT' file Open for write Error */
          //Error_Handler();
        else
          /*##-5- Write data to the text file ################################*/
          res = f_write(&MyFile, wtext, sizeof(wtext), (void *)&byteswritten);
          if((byteswritten == 0) || (res != FR_OK))
            /* 'STM32.TXT' file Write or EOF Error */
            //Error_Handler();
          else
            /*##-6- Close the open text file #################################*/
            f_close(&MyFile);
            /*##-7- Open the text file object with read access ###############*/
            if(f_open(&MyFile, "STM32.TXT", FA_READ) != FR_OK)
              /* 'STM32.TXT' file Open for read Error */
              //Error_Handler();
            else
              /*##-8- Read data from the text file ###########################*/
              res = f_read(&MyFile, rtext, sizeof(rtext), (UINT*)&bytesread);
              if((bytesread == 0) || (res != FR_OK))
                /* 'STM32.TXT' file Read or EOF Error */
                //Error_Handler();
              else
                /*##-9- Close the open text file #############################*/
                f_close(&MyFile);
                /*##-10- Compare read data with the expected data ############*/
                if((bytesread != byteswritten))
                  /* Read data is different from the expected data */
                  //Error_Handler();
                else
                  /* Success of the demo: no error occurrence */
                  //BSP_LED_On(LED1);
FATFS_UnLinkDriver(SDPath);
When debugging, it returns from " if(f_open(&MyFile, "STM32.TXT", FA_CREATE_ALWAYS | FA_WRITE) != FR_OK)" to error handler, so it can not open the file. What may the problem be? Any advise...
